Results 1 to 15 of 15
Reload Thread: 1 or 2 ports for 2 12 inch t1s
    FOSGATE JOE's Avatar
    FOSGATE JOE is offline R.F team and 49er fan!!!!
    Dec 2004
    CALI
    1,496
    Icon32 1 or 2 ports for 2 12 inch t1s
    hey guys i need your help if i should go with1 or 2 ports the box is 3.33cuft i have 2 power t1s 12 inch subs they are 6oo rms/ the box tune will be 32hz and the subs will sharing the same space
    ref.gohillaaudio
    JoseMCeee's Avatar
    JoseMCeee is offline $tack
    Sep 2004
    Bay Area, CA
    2,250
    Re: 1 or 2 ports for 2 12 inch t1s
    its a lote easier to just do one port. From what i know there is no real difference. Take into acount that you will probably have to do separate chamber for two ports. I dont think single chamber will two ports would sound that good. Not too sure tho. IMO just do single port. Much easier.
    Dec 2004
    CALI
    1,496
    thaxs for you're input
    ref.gohillaaudio
    mobileaudio219's Avatar
    mobileaudio219 is offline Senior VIP Member
    Dec 2004
    Central, Missouri
    318
    If you are using round ports you can you as many as you like/can.... If you you are using a slot port, then its easier to use just one, but you can use 2.... I just got done building a box for my cousins (2) 12" kicker comp vrs, its a common with 2 ports, it sounds good...
    Dec 2004
    CALI
    1,496
    yes i would like to use a round port so you think i can get by with one like jose said
    ref.gohillaaudio
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    it really all depends on the calculations. Im not a ported box designer so im not too sure about this kind of stuff. If the port has to be really long and the box isnt long enuff, then do 2. If 1 is long enuff, do 1.
    Dec 2004
    CALI
    1,496
    i forgot to add i will be using 4 inch pip thats what i got
    ref.gohillaaudio
    swimfreak26's Avatar
    swimfreak26 is offline I am cool
    Aug 2002
    East Lansing, MI
    3,132
    Doesn't matter how many ports you use. The only difference between using 1 and 2 is the port length, as each port will be shorter using 2 then the single port if 1 were to be used
    Fuc, how come when I copy and paste **** it never gives me the cool blue thing in my sig. Sonofa*****withhotredtabascosauceonmynutz!!!!!
    References: g30ffr3y,Cjjackson85,Pearldrummer, Rattlebrain, Harrison486, excelerater, ax600, XtrmAudioCncpts
  9. #9
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    31
    13,103
    8 Post(s)
    Quote Originally Posted by JoseMCeee
    thats not true
    its purely cosmetic and you can use asingle chamber.
    im doing one right now.
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
  10. #10
    Dec 2004
    CALI
    1,496
    thank you guys for your input i will try the one port to day and let you known how it whent?
    ref.gohillaaudio
  11. #11
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    26
    3,614
    if you are using 4" PVC, you should use 4 ports....
  12. #12
    Dec 2004
    CALI
    1,496
    Icon14 Re: 1 or 2 ports for 2 12 inch t1s
    Quote Originally Posted by Moe Lester
    well i did the one port and it hits good but i feel i can get more out of those subs so give me some good idea's and i will buy those designs or if some one knows a beter way to do it
    ref.gohillaaudio
  13. #13
    Moe Lester's Avatar
    Dec 2003
    Houston, TX
    26
    3,614
    4 cubes, 50 sq in port, tuned to 32 will be nice
  14. #14
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    ^haha rolf copter. By the wat subs are these again?
  15. #15
    Dec 2004
    CALI
    1,496
    rockfordfosgate power t1s 12inch that's the name of the subs
    ref.gohillaaudio
  1. Multiple ports different sizes
    By HAVINGFUN in forum Enclosure Design & Construction Help
    Last Post: 12-13-2004, 04:18 PM
  2. 3 12 inch sub help
    By AcidNoiz in forum Enclosure Design & Construction Help
    Last Post: 12-10-2004, 12:04 AM
  3. Any tips on where to find free instructions on how to install 12 inch subs?
    By Kiys420 in forum Wiring, Electrical and Installation Help
    Last Post: 09-26-2004, 11:55 PM
  4. Mounting a 12 inch sub to a custom box
    By Heresy in forum Wiring, Electrical and Installation Help
    Last Post: 04-17-2004, 12:47 AM
  5. jbl bp600 and 2 12 inch he2's? good combo?
    By mopar in forum Amplifiers
    Last Post: 08-11-2002, 07:29 AM
