Results 1 to 7 of 7
Reload Thread: port help
    mabel4life's Avatar
    mabel4life is offline Frank the Tank
    Feb 2005
    central PA
    31
    298
    port help
    im building a box for 2 12" powerbass PB-B125D
    here are the specs
    50 oz. magnet dual 4 ohm vc
    power handling 250 watts/ 350 watts peak
    sensitivity 87 dB @ 1W/1M
    FS= 29.8 HZ, QTS= 0.78, VAS= 118.9 Hz
    Frequency Response 30 Hz - 1 kHz
    what size should i make the ports?
    joeldirt's Avatar
    joeldirt is offline Integrity
    Dec 2004
    Eureka, CA
    36
    467
    1 Post(s)
    Re: port help
    The size of the ports should be 4 inches in diameter where ever possible. The larger the port, the lower the port noise. But the length of the ports depend on how large or how small the enclosure is and what the tuning frequency you want. Let us know if you are going to put the subs in a box with individual chambers, or one large one, and what the dimensions you have to work with.
    _____________________________________________
    Different People, Different Ways...
    mabel4life's Avatar
    Feb 2005
    central PA
    31
    298
    Re: port help
    the box will be one large one that will sit behind my back seat in the trunk. It will be around 36" long and 16" in heighth.
    joeldirt's Avatar
    Dec 2004
    Eureka, CA
    36
    467
    1 Post(s)
    Re: port help
    Quote Originally Posted by mabel4life
    a suggestion:
    36w X 24D X 16 tall outer dimensions using 3/4" MDF will give you 6.5 cu ft. which is good, now oyu can add in the bracing to reduce vibrations. Keep reinforcing until you reach a 5ft3 box lets say you want to tune the box to 32hz.........
    if you were to use four 4" ports, the length would have to be 23.5 (you would have to put them side to side rather then front to back so they wont bump into back wall. ( I wouldnt suggest this design)
    if you had three 4" ports, they would have to be 16 7/8" long
    two 4" ports= 10 1/8 long.
    http://www.audiobahninc.com/tech/Cal...LengthCalc.htm
    http://www.the12volt.com/caraudio/boxcalcs.asp
    a slot vent 3" wide would have to be 15 13/16
    4" wide would have to be 24 1/4
    every one does things different, so you should have a few people putting in their input. what you decide to chose is up to you. Good luck
    mabel4life's Avatar
    Feb 2005
    central PA
    31
    298
    Re: port help
    would you suggest a slot vent over ports. keep in mind this will be in my trunk. thanks for the info
    joeldirt's Avatar
    Dec 2004
    Eureka, CA
    36
    467
    1 Post(s)
    Re: port help
    Even when you know, you never know.... you know? No one has all the answers, every one only holds thier own opinion. I always use round ports. I never used a slot port. Slot ports are suposed to be good to reduce port noise. I never have any problems with port noise in the round ports, because I always round over the ends. I also wrap the ports with 3/4" weather strip to help take away vibrations in the port. The round port requires PVC obviously, so if you have MDF laying arround scrap, you could probably jsut use that without having to buy PVC. it is in the trunk so asthetics aint a big issue, unless you plan on showing off your work. I think round ports look nicer thats why I always use round ones. As far as difference between the two.... as long as there isnt anything miscalculated, or assembled poorly, There really is no difference. Both things I guess slot ports may help with reinforcing the box if you think about it, that is a plus, But I flush mount the internal ends of the ports into a suport or internal brace so I can round over the edges cleanly and give suport in the box, while also reducing port vibrations. SO both have their plusses. I guess the disadvantage in my own opinion in slotted boxes is the way they look. I for some reason don't like them that much. Disadvantage of a round port may give more port noise. key word "may". take a few extra steps and it won't be noticable at all, or very little.
    mabel4life's Avatar
    Feb 2005
    central PA
    31
    298
    Re: port help
    thank you. your info is much appreciated.
  1. My 13kv2 ported box! (pics)
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 11-18-2004, 09:31 PM
  2. port bend question
    Last Post: 11-01-2004, 08:06 AM
  3. port volume Q
    By maniackilla in forum Enclosure Design & Construction Help
    Last Post: 10-01-2004, 03:54 AM
  4. J-
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 01-06-2003, 03:50 PM
  5. Box for port wars...
    By F150Matt in forum Enclosure Design & Construction Help
    Last Post: 01-05-2003, 03:22 PM
