r the specs for a sql box on reaudio.com accurate? its for 2.5 cubes at 35 hz i think......
2001 Mitsubishi Eclipse
Coming soon!!
1)Ported Enclosure 4.0 cubes (after dis.)
Ordered
60 sq ft. EDead V1(for now, arrived Mar 9)
2 12" RE SE's(arrived Mar 4)
Memphis 16-MC150(arrived Dec 27)
CDT Audio EF61CFi 6.5" Component Set(arrived Jan 8)
Memphis 16-MC1000D(arrived Jan 3)
System has been put on hold.....saving for a RIPP mods Stage 2 Supercharger
For the 12...yes
but you can go bigger or smaller, I would not go below 2 cubes for the 12
2.1^3 @ 32hz
fantastic sized box for that sub!!!!!!!
___________________________________________
my setup
2004 honda accord V6 EX / Nighthawk Black Pearl 2 door coupe
premier 860 / eD 16Ov.2 / viper 1200.1 / 2.2^3 @ 30hz / stinger bullet interconnects
girlfriends setup
2004 pontiac sunfire / silver metallic / 2dr coupe
eD e12o.44 / memphis 1000d / 1.6^3 sealed box
here we are
face to face
same energy
you and me
dont want to be
enemies
references:
kevin85193
JAZN
swimfreak26
what about for the SE? it says a sql box should be 1.8ft^2 at 32Hz, is this good?
What are you saying? To big for the SE?
wtf i thought 1.8 is sql for the SE
DTM HATER
lol
i have a single SE in a 1.5 @ 35 HZ
it pounds
www.BassHeadsENT.net for all your custom enclosure needs
Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
Robin@BassHeadsENT.net
Check this thread for all the build logs being posted.
http://www.caraudio.com/forums/suppo...ks-thread.html
it is. there's some confusion, i was talking about the 12" if that clears it up.Originally Posted by ighettoboyi
you'll like 1.5+ with around 15sq in of port.
What the f00k happened to this place?
The plans are in effect for two RE 12SE's. @ 2.5ft3 tuned to 35 hz. (THat is for each sub) Raised fiberglassed sub mounts, and two 4" round ports per chamber. I have full confidence in it's ability to pound the SH*t out of that car. It will be going in a CRX. The actual box is 3.08ft3 befor internal volume is taken up by ports, sub, and bracing.
Bookmarks
