Results 1 to 15 of 15
Reload Thread: Width on 3 Tens
    JoseMCeee's Avatar
    JoseMCeee is offline $tack
    Sep 2004
    Bay Area, CA
    2,250
    Width on 3 Tens
    Sup webolizations. Endubadibaly I need a quick oppinion. I gizzot like 35 wizzith, 14 hizzeight, and unlimited depth. <- Well enuff to clizzear the cubic requirement. Is this enuff for 3 tens? Fashigady
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    Re: Width on 3 Tens
    puppie_chow's Avatar
    puppie_chow is offline Pwn3d!
    Mar 2002
    Pwn3dv1ll3, USA
    705
    Re: Width on 3 Tens
    yes it's enuff, happy?
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    Re: Width on 3 Tens
    ok seriously tho. Will 35 be enuff? I wanna keep the front flat tho. No hexagon thing. I was thinking since I have 14 height i could mount the middle ten a little higher than the two bottom.
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    Re: Width on 3 Tens
    Moe Lester Get Online!!
    Primo's Avatar
    Primo is offline ibtl
    Apr 2004
    Grants Pass, Oregon
    26
    1,319
    Re: Width on 3 Tens
    Quote Originally Posted by JoseMCeee
    you are gizay.
    4 life
    80INCHES's Avatar
    80INCHES is offline EPICENTERGLUED 2 ME
    Jan 2005
    WESTCHESTER, NY
    32
    6,963
    Re: Width on 3 Tens
    yes it will be enough.......even if u had 11 inche speakers ....it will be enuf
    80
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    Re: Width on 3 Tens
    but what about the space in between the subs? Like where they are screwed. Will those piece come out too thin?
  9. #9
    Oct 2003
    Tampa, FL
    73
    Re: Width on 3 Tens
    It should be braced between the subs anyway.... a 14x35 panel is begging for bracing, even if you only had one sub on that panel.
  10. #10
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    Re: Width on 3 Tens
    as in makin the chambers separate?
  11. #11
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    30
    873
    Re: Width on 3 Tens
    In my setup i had 38" I fit 3 10's in with much room to spare + a port, i was working with about the same hieght too. So yes you do have enough room for 3 10's
  12. #12
    Oct 2003
    Tampa, FL
    73
    Re: Width on 3 Tens
    Separate chambers arn't necessary, and you're better off with one common chamber for a ported application. But you should still have some form of bracing. Use a divider just like it was a separate chamber, but cut out some of the meat so that air can freely pass through. It should end up looking like a +. Or you can just use a 3" or bigger hole saw and put a bunch of holes in the dividers.
  13. #13
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,368
    Re: Width on 3 Tens
    Bracing is overrated
    Dont believe me, ask Mrray13
  14. #14
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    31
    13,134
    8 Post(s)
    Re: Width on 3 Tens
    Quote Originally Posted by DBfan187
    LMFAO
    thats the funniest thing ive seen in a minute here
    **** LOL
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    Robin@BassHeadsENT.net
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
  15. #15
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    Re: Width on 3 Tens
    ^fashigalo. But anyways I think i would be too lazy to brace dat shieeet. By the way this is gonna be a sealed box.
  1. is this port width okay??
    By flakko in forum Enclosure Design & Construction Help
    Last Post: 02-14-2005, 11:49 PM
  2. 4 tens
    By silverlude56 in forum Subwoofers
    Last Post: 02-13-2005, 01:39 PM
  3. ports- 1/8th width to hight ratio
    By d cha p in forum Subwoofers
    Last Post: 12-05-2004, 07:30 PM
  4. SONY XPLOD SUBS(4 tens)
    By MR_LOWRIDER in forum Subwoofers
    Last Post: 03-01-2002, 08:48 PM
  5. i have 4 alpine t-s tens
    By v12rob in forum Subwoofers
    Last Post: 01-27-2002, 03:30 PM
