Results 1 to 14 of 14
Reload Thread: Fiberglass + MDF
    00StealthSE's Avatar
    00StealthSE is offline Member
    Feb 2005
    St. Petersburg, FL
    40
    Fiberglass + MDF
    I have recently purchased a Infinity 1230w Reference 12" sub, I am not going to be installing this until the summer time, when I complete my whole system, but I was wondering. If I were to build a fiberglass mold of the corner of my trunk by the tailights, for each sub, and I used an MDF face for the front of the enclosure, would using the "Water Method" to measure the volume of the enclosure ruin the MDF?
    SurgicaL's Avatar
    SurgicaL is offline Senior VIP Member
    Feb 2005
    Va Beach
    305
    Re: Fiberglass + MDF
    foam peanuts it not %100 accurate but can get it dam close....
    do it 3x and take the average, all three times should be close though....
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    35
    2,811
    Water makes MDF swell, don't use it. Use the peanuts like SurgicaL said.
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    sand or dirt works well. if you are that nervous about using water (yes, tis a bad idea)
    coat the piece of MDF with resin previous to attachment.
    then its waterproof
    Feb 2005
    St. Petersburg, FL
    40
    Not nervous lol, I know it would warp it or something, resin idea is a good one. Is there a site that fully explains the steps of the water/packing nuts method, because i dont understand how you measure the volume, with the peanuts in the box after you put them in the enclosure and what not!?
    Nov 2004
    Grove City, OH
    31
    2,236
    no man, it's easy... you could do any of the following.
    take a two liter bottle, or a gallon milk jug, or anything. fill it up as many times as you have to, and dump into enclosure, and keep track of how many times (how many liters, or gallons) it takes to fill up. then go to a conversion website and plug numbers in.
    take a lot of packaging peanuts, and put them in your enclosure (put them in lightly, don't push them in), then take all of the peanuts out (make sure you don't crush too many of them) and then put it into a large box. Make the peanuts as flat as you can, then measure the height, width, and length of the peanuts.
    as for making a fiberglassed enclosure that has a precise volume, i'm almost sure there's no way to do it. like, saying "i want to glass a 0.55 cubic foot enclosure exactly", i dont think it will happen. you can get close by guesstimating.
    req's Avatar
    req
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    yea, just gotta measure the 'volume' as you put it into the enclosure. once its filled, add up all the amounts you put in. i like using an 8cup measuing cup. then just convert to cubic feet (online, just type "XX cups to cubic feet" in google, and it will give you an exact number).
    as for getting the right enclosure size - just shoot for larger than what you need\want.
    if you want 1.0, shoot for 1.3 or 1.5, then just add some wood or some closed cell foam to the inside. and remove\add wood or whatever until you reach your desired volume. its really quite a bunch of common sense.
    i dont understand why people cant just think of this stuff. most of my ideas are just that. ive never done half the stuff i talk about, but its all common sense
    lol. shouldnt have said that eh - i suppose most of the stuff i talk about is from things ive read or talked to people about... and then common sense is added i...
    SurgicaL's Avatar
    Feb 2005
    Va Beach
    305
    Quote Originally Posted by req
    w3rd
  9. #9
    Feb 2005
    St. Petersburg, FL
    40
    Where do you buy some Carpet, like they use in your trunk and stuff, to cover the boxes and everything.
  10. #10
    Nov 2004
    Grove City, OH
    31
    2,236
    You can find Carpet at Walmart. It's $7 for a roll, it's 36" wide and like 6 or 8 feet long.
    Comes in gray, black, and tan.
  11. #11
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    Quote Originally Posted by GCAdidas13
    thats the stuff i use and it works great.
    also check out www.partsexpress.com for carpet.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
  12. #12
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    30
    2,211
    17
    an easier and quicker way to measure the volume with water is weighing it. simply weigh your enclosure, record. weigh a liter of water (make sure to subtract the weight of the container), record. fill the enclosure with water, record. subtract the initial enclosure weight (the weight with out water), divide it by the wieght of the liter of water, then convert to cubic feet. thats what i'd do, but the other ways would work fine.
  13. #13
    Sep 2004
    30
    2,211
    17
    ps, a plus with using water is you're able to find any pinhole leaks, then seal them with silicone.
  14. #14
    iamamp3pimp's Avatar
    iamamp3pimp is offline Bass Heads Entertainment
    Nov 2003
    Tampa FL
    36
    13,103
    21 Post(s)
    that doesnt work if it is a huge trunk spare tire well enclosure
    www.BassHeadsENT.net for all your custom enclosure needs
    Offering build service and expertise in the Tampa area as well as enclosures shipped nationwide!
    [email protected]
    Check this thread for all the build logs being posted.
    http://www.caraudio.com/forums/suppo...ks-thread.html
  1. ported fiberglass box.
    By derek33 in forum Enclosure Design & Construction Help
    Last Post: 02-24-2005, 04:09 PM
  2. Filling Gaps Between MDF And Fiberglass
    By djXternal in forum Enclosure Design & Construction Help
    Last Post: 01-20-2005, 12:15 PM
  3. new fiberglass box question
    By badboyzx2 in forum Enclosure Design & Construction Help
    Last Post: 12-30-2002, 02:44 PM
  4. 3/4 Mdf 1" Mdf 5/8 Mdf ???
    By schrunk in forum Subwoofers
    Last Post: 01-29-2002, 09:22 AM
