Results 1 to 3 of 3
Reload Thread: 2 Magnums Sealed HELP!
    Feb 2004
    Ridgecrest, CA
    27
    418
    Hello,
    Im going to make a sealed and ported box for my magnums, but I have a question on the sealed box. I was going to make a 3.5ft^3 box and split it into 2 chambers with a piece of wood in the middle of the inside of the box so each magnum would have 1.75ft^3. I want to wire the magnums together to get a 2 ohm resistance, but I was thinking about the box and I was wondering how I am supposed to wire the 2 subs together if there is that piece of wood in the middle separating the 2 of them? Would I just make a small hole for the wires and stick them through and then caulk the hole to prevent air from getting through or wat? I'm confused, plz help
    Thanks
    Pioneer DEH-P7700MP
    JBL BP1200.1
    SI Magnum D2 12" (Claw basket) reconed by Fi
    1.25ft^3 sealed
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,367
    Re: 2 Magnums Sealed HELP!
    1. drill hole
    2. insert wires
    3. caulk hole
    4. let dry
    You shouldnt be confused since you answered your own question
    bass maniak's Avatar
    bass maniak is offline Team Poundin Sound
    Aug 2002
    Faust, Alberta ( CANADA )
    25
    3,182
    113
    u can run the wires out the box from each seperate enclosure, making re-wring it easy for convienance. if you ever need to play around or what not.
    that what i do anyway, saves taking out screws over n over again.
    if your not planning on playng around much then it doesnt really matter, do whatever u wanna do with it man but yes that is what you can do.
    Chuch AKA Tha Mad Scientist
    Team Poundin Sound
    Joker Kustoms
    Boost Junkie Motor Sports
    Street Poetry Productions
    Wreaking Havoc Records
  1. sealed Brahma/XXX ??
    By BoNkA in forum Subwoofers
    Last Post: 01-31-2005, 08:48 AM
  2. who has a XXX sealed?
    By g30ffr3y in forum Subwoofers
    Last Post: 01-22-2005, 08:24 PM
  3. JL Audio 13W7: Sealed or Ported?
    By PickupBass in forum General Discussion
    Last Post: 11-30-2004, 11:58 AM
  4. Replies: 1
    Last Post: 10-02-2004, 09:46 AM
  5. ported / sealed ??
    By limitkid7 in forum Subwoofers
    Last Post: 12-09-2002, 11:29 AM
