Results 1 to 5 of 5
Reload Thread: fiberglass console
    yz_gt69's Avatar
    yz_gt69 is offline Senior VIP Member
    Dec 2003
    canada
    29
    339
    fiberglass console
    Hey everybody,
    I'm building a fiberglass console for my truck. It will host two 10 inch subs.
    Problem:
    I only need part of the airspace for the subs. How do I have the console as one flowing piece, but have one part as a sealed chamber, and the other part as the rest (front) of the console?
    I know it's kinda hard to understand what I'm sayin, but you can kinda put it together...
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    25
    2,211
    17
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Midwest Ohio
    26
    3,509
    Re: fiberglass console
    yes, Just make some sort of divider. You could also just make a fiberglass one also.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    Sep 2004
    25
    2,211
    17
    yea, but i have found when working with fiberglass, it is best to use wood in some parts when possible. large planes of fiberglass (parts without curves or angles) are the most vulnerable to flexibilty and weakness.
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    27
    15,432
    21
    make as much out of MDF as you can. round all the edges off. pretend you are doing paper mache... how would you make it flowing?
    use your imagination and be creative.
    heres some ideas. look at their project pictures-
    http://www.stevebrownuniversity.com/sbu/index.htm (looks like its not up ATM - but it should be shortly)
  1. ported fiberglass box.
    By derek33 in forum Enclosure Design & Construction Help
    Last Post: 02-24-2005, 04:09 PM
  2. new fiberglass box question
    By badboyzx2 in forum Enclosure Design & Construction Help
    Last Post: 12-30-2002, 02:44 PM
  3. fiberglass ported
    By jjoven1225 in forum Enclosure Design & Construction Help
    Last Post: 12-25-2002, 04:38 PM
  4. Anyone ever made a fiberglass console for a TV on the dash of a F150?
    By F150Matt in forum Wiring, Electrical and Installation Help
    Last Post: 10-28-2002, 09:50 PM
