Results 1 to 9 of 9
Reload Thread: Ported 10 L7"
    ttsquared100's Avatar
    ttsquared100 is offline Senior VIP Member
    Jan 2005
    the south
    247
    Ported 10 L7"
    Im lookin for plans for a single kicker 10 l7...pure spl this is going to be project...i am looking for loudest possible what have you guys done before
    HAVINGFUN's Avatar
    HAVINGFUN is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    Re: Ported 10 L7"
    Look on their site at the large end of the ported enclosures. Have about 30 inches of port area and tune to around 40 hz and you will have a very loud 10 inch sub. It might not sound great but you said you were after SPL
    Jan 2005
    the south
    247
    Re: Ported 10 L7"
    yea im playin around on the box building program on the computer but i am a novice and this is a project so it should be fun...might take me a few tries but at least i dont need that much wood lol if anybody else has actual plans id like to see them
    also anybody done a snail-shell box how in the world do you calculate those measurements...
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    25
    2,211
    17
    Re: Ported 10 L7"
    apparently you should find the resonant frequency of your car before you select your tuning. bassbox pro 6 is good for this kinda thing. i'd say 2.75-30 cubes, and tune around 40 Hz? perhaps you should consider some sort of bandpass design if you're trying for pure SPL.
    Jan 2005
    the south
    247
    Re: Ported 10 L7"
    hmm...where can i get bassbox pro 6? yea im prob gonna tune it to an explorer i know im in the low to mid 40hz range...i screwed up with my last box tuned to 36hz cause i thought i wanted it to sound clear but i have become more Knowledgeable since then.
    i am under the impression that ported is louder than bandpass. why do you suggest bandpass.
    HAVINGFUN's Avatar
    Aug 2004
    Keller, TX DFW area
    2,030
    17
    Re: Ported 10 L7"
    Bandpass can be very effecient and tuned to play a small range of freq. You can tune that box to peak very hard at lets say 50 hz or so but will not play well above or below that.
    http://jlaudio.com/tutorials/magic/bandpass.html
    Jan 2005
    the south
    247
    Re: Ported 10 L7"
    **** these boxes get pretty complicated...i guess when i thought of bandpass i thought of the crappy best buy ones with plexi-glass and neons...since its a hobby just sometin to do i might try and build several boxes...but im gonna go do some more research on bandpass thanks...
    anybody else out their messed around with a single ten
    Naxis2k1's Avatar
    Naxis2k1 is offline grade A whiteboy
    Jul 2004
    Phoenix
    598
    Re: Ported 10 L7"
    build a sealed box. run some feq sweeps whatever feq hits/sounds the loudest tune for that. or near that.
  9. #9
    Jan 2005
    the south
    247
    Re: Ported 10 L7"
    do you think i can use one of those handheld dB meters to figure that out...cause for me to get on a mic would be tough. how about the formula that bass mechanik gives out is that accurate. what i am tryin to say is the resonant frequency of your car the same number you should tune your box to???
  1. Custom Ported Box From Woodland Cabinetry
    By stuwad21 in forum General Discussion
    Last Post: 02-25-2005, 06:18 PM
  2. Ported RE 8 or Sealed RE 10?
    By ChuteBoxe515 in forum Subwoofers
    Last Post: 01-03-2005, 07:57 AM
  3. 1 L7 10 ported, 2 L5 10s sealed, or 2 comp vr 12s sealed?
    By infinity1412 in forum Subwoofers
    Last Post: 11-11-2004, 09:59 AM
  4. Ported Box for Two Clarion 10 inch
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 12-17-2002, 05:10 PM
  5. question about ported boxes
    By crzybob77 in forum General Discussion
    Last Post: 09-17-2002, 09:50 PM
