Results 1 to 9 of 9
Reload Thread: Ported box for 15" AW1571T
    yporippa_808's Avatar
    yporippa_808 is offline Junior Member
    Mar 2005
    Hawaii
    I know that this sub is junk but whatever, this is my first system ever. i have no clue about building boxes but i heard that a ported box is the way to go if you want loud bass. i dont really care about the quality.
    these are the specs:
    the recommended Ported Box Dims: 1.70 - 3.55 cu.ft.
    height: 19 inch
    width: 17 inch
    depth: 16 inch
    19x17x16=5168.00
    5168.00/1728=2.99 cu ft
    and to find the port:
    (17+0.75)x19x16-0.75/1728=3.37
    is ths correct? i dont know what the 3.37 is though is that how big the port is??
    any help would be greatly appreciated
    Mar 2005
    Hawaii
    Re: Ported box for 15" AW1571T
    bump
    and also, what would the inside of the box look like?
    Like this:
    _______________
    I _________ I
    I I I
    I I I
    I I I
    I I I
    I I__{_____}__I
    How big are the peices that make the port) the second row of I's and the parallel solid line?
    Mar 2005
    Hawaii
    never mind that top drawing, it didnt work
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    30
    3,509
    try drawing something in MS paint to show us what you mean. Then host it from www.imageshack.us.
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    Feb 2004
    Central Ohio
    30
    3,509
    Also what size are you going to make you port? Round or squeare. Like the width and height of the port then i will help you figure rough length.
    97 Monte Carlo
    Mar 2005
    Hawaii
    i dont know what size i should make the port... i was going to make it rectangular though.
    Mar 2005
    Hawaii
    here is a little diagram, how big should i make the red lines?
    Attached Thumbnails Attached Thumbnails Ported box for 15" AW1571T-sub-box.jpg
    Feb 2004
    Central Ohio
    30
    3,509
    you are not going to fit a very wide port on a box that is 17" wide with 15" being used for the sub and 2 1/4"" used for the thickness of the wood since you will have 3 boards. 2 outside edge ones and one internally for the port. So you need to make your face wider.
    97 Monte Carlo
  9. #9
    Mar 2005
    Hawaii
    so should i make the width like 21
    18x21x15=5670
    3.28125 cu ft
    height:18
    width:21
    depth15
  1. I have the sealed box specs, what do i need to make it ported?
    By derek33 in forum Enclosure Design & Construction Help
    Last Post: 02-28-2005, 05:35 PM
  2. My 13kv2 ported box! (pics)
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 11-18-2004, 09:31 PM
  3. SX Ported Box
    By Jplaya135 in forum Enclosure Design & Construction Help
    Last Post: 10-05-2004, 08:48 PM
  4. question about ported boxes
    By crzybob77 in forum General Discussion
    Last Post: 09-17-2002, 09:50 PM
  5. ported box size++++? port+++? SPL+++?
    By dreamer in forum Subwoofers
    Last Post: 05-09-2002, 12:36 AM
