Results 1 to 5 of 5
Reload Thread: I have the sealed box specs, what do i need to make it ported?
    derek33's Avatar
    derek33 is offline CarAudio.com Elite
    Oct 2004
    mass
    30
    622
    So i was starting to put together my sealed box. and after realizing how much work these are (my first box) that i should just go for making it ported.
    here are the dimensions:
    24" deep -- 16" tall -- 33" wide.
    Ive been using a sealed box so far, and i have the subs facing my rear seat in my jeep ( i found it sounds best for me that way) Is it a bad idea to put the ports facing the trunk while the subs face the front?
    also, with those dimensions, what size/how many ports should i use, id plan on buying these:
    http://www.partsexpress.com/pe/showd...number=268-352
    And this box is for my current/temperary setup, 2 15" mtx 8000's.
    I know i am limited due to choosing the box size before i thought about porting it, but im trying to get a frequency of 28-30 hz (lower if possible/recomended). my subs are plenty loud in the car, so im looking for 75% SQ. 15% SPL
    God's my co-pilot... but the Devil is ridin' shotgun!
    Car: 97 Grand Cherokee v8. 318ci.
    3 header back exhaust
    242 - hp 30 - 8.8
    6" lift
    35" BFG's.
    derek33's Avatar
    Oct 2004
    mass
    30
    622
    Re: I have the sealed box specs, what do i need to make it ported?
    up
    242 - hp 30 - 8.8
    6" lift
    35" BFG's.
    derek33's Avatar
    Oct 2004
    mass
    30
    622
    i will also be adding two 3/4 dowels. one horizontal and one vertical.
    up
    242 - hp 30 - 8.8
    6" lift
    35" BFG's.
    Buckshot's Avatar
    Buckshot is offline CarAudio.com Elite
    Jan 2005
    Michigan
    563
    Your ported boxis going to need to be much bigger, then the sealed counterpart... do you have those specs?
    derek33's Avatar
    Oct 2004
    mass
    30
    622
    I know ported boxes need to be bigger then sealed, but that box is reletivly big. I dont have the list of stats on my woofer which describe the recomended box size and such, but i know that i was taking a risk by building a sealed box this size for these subs.
    242 - hp 30 - 8.8
    6" lift
    35" BFG's.
  1. sub selection
    By DeKaL44 in forum Subwoofers
    Last Post: 12-08-2005, 03:35 AM
  2. Replies: 12
    Last Post: 02-23-2005, 11:42 AM
  3. Large sealed box or small ported box?
    By Raven in forum Enclosure Design & Construction Help
    Last Post: 01-20-2005, 04:58 PM
  4. did i make my sealed box too big?
    By lamontjersey in forum Enclosure Design & Construction Help
    Last Post: 12-08-2002, 09:31 PM
  5. Ported L7 12'' in F150 single cab vs 2 12'' sealed?
    By F150Matt in forum Wiring, Electrical and Installation Help
    Last Post: 07-07-2002, 06:34 PM
