Results 1 to 9 of 9
Reload Thread: Port calculation???
    Buckshot's Avatar
    Buckshot is offline CarAudio.com Elite
    Jan 2005
    Michigan
    563
    Port calculation???
    Alright, someone PLEASE figure out this port. I'm leaving to go get some wood, and I hope itll be here when I come back.
    D=16.5"
    W=30"
    H=15"
    I want to tune it to ~30-32 Hz. SQL kinda setup.
    Driver vol = .12 Cube
    Pleaseeeeeeee help meh!
    traksta15's Avatar
    traksta15 is offline I love lamp.
    Dec 2003
    Mcalester, Ok
    26
    4,065
    Re: Port calculation???
    im sort of a newb at port calculations, but these help me out........
    http://www.carstereo.com/help/Articles.cfm?id=31
    http://www.eatel.net/~amptech/elecdisc/spboxnew2.htm
    Kenwood ddx712
    boston acoustics z6
    arc audio 300.4
    40 sq ft damplifier
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    31
    2,811
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    28
    15,426
    21
    www.r3q.net/port.html
    www.r3q.net/req_files/portcalc.zip (link on the above page is down ATM - so use this one)
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    25
    2,211
    17
    i'll give you the bassbox pro calculation. its usually off by 1-2 Hz., but hardly audible. i'm much too lazy right now to do it properly.
    Sep 2004
    25
    2,211
    17
    and what should your port area be?
    and what the hell was wrong with your glass box?
    ANeonRider's Avatar
    Aug 2004
    Saskatoon, SK, CAN
    31
    2,811
    Go for 25in^2
    Sep 2004
    25
    2,211
    17
    with the dimensions above, i got a port length of 26.14, width of 1.75, and height of 14.5 for a tuning of 30 Hz. This brings the volume down to 2.79 ft. ^3. this was all done on bassbox pro, so it may be off by 1 or 2 Hz. (Its usually higher than it really is, so its probably somewhere around 32 Hz in reality). hope this helps.
  9. #9
    Buckshot's Avatar
    Jan 2005
    Michigan
    563
    Quote Originally Posted by bcarpenterfhl
    Thanks buddy. :+)
  1. box and port calculation review
    By derek33 in forum Enclosure Design & Construction Help
    Last Post: 02-06-2005, 02:21 PM
  2. Port calculation
    By monte_carlo97 in forum Enclosure Design & Construction Help
    Last Post: 02-03-2005, 09:34 AM
  3. Is my port calculation correct?
    By btnhfan in forum Enclosure Design & Construction Help
    Last Post: 11-20-2004, 03:17 PM
  4. port bend question
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 11-01-2004, 08:06 AM
  5. J-
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 01-06-2003, 03:50 PM
