Page 1 of 5 1 2 3 4 5 LastLast
Results 1 to 15 of 74
Reload Thread: Fiberglass Mount for TV Work Log
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    25
    2,211
    17
    today i started working on my install for a 7 inch lcd screen. it will go where my cup holders are. today i just glassed up a mold of the cup holders. i think this will be a pretty easy project. here are some pics of the progress. i will post pics of the actual center console once the resin dries.
    swaptrex's Avatar
    swaptrex is offline Supporting Member
    Nov 2004
    Michigan
    26
    2,014
    Re: Fiberglass Mount for TV Work Log
    def keep us updated, i want to do something similar to this in my car above the headunit.
    Sep 2004
    25
    2,211
    17
    most definitely will
    mas picturas:
    traksta15's Avatar
    traksta15 is offline I love lamp.
    Dec 2003
    Mcalester, Ok
    26
    4,066
    looks sweet, keep up the good work.
    Kenwood ddx712
    boston acoustics z6
    arc audio 300.4
    40 sq ft damplifier
    JAZN's Avatar
    JAZN is offline CarAudio.com Veteran
    Sep 2004
    SoCAL
    28
    11,370
    15
    good stuff. i like ur work.
    Sep 2004
    25
    2,211
    17
    when i stretch the fabric over the whole thing, which will be better: grill cloth, old t-shirt, or fleece?
    heres an image for those who dont quite understand what i'm doing. the reason i molded the cup holder is so i can tightly fit this mount without screwing into the center console (leased car). it obviously will be less angled then the diagram below displays.
    ps, the tv will be on the other side, my bad.
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Midwest Ohio
    26
    3,509
    looks like the project in my car i just did.
    Looking good. Keep us updated
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
    2kchevy06civic's Avatar
    2kchevy06civic is offline Learn to swim
    Oct 2004
    Arizona Bay
    26
    11,449
    looks cool so far
  9. #9
    Sep 2004
    25
    2,211
    17
    but which of the previously mentioned fabrics will work best? i'm thinking grill cloth or t-shirt; i dont think i need the thickness of fleece.
  10. #10
    Feb 2004
    Midwest Ohio
    26
    3,509
    t-shirt should work pretty well. I used like spandex material for mine though.
    97 Monte Carlo
  11. #11
    Feb 2004
    Midwest Ohio
    26
    3,509
    Also what kind of finish you going to put on it. I used truck bed liner on mine and it turned out really good. Also means you don't have to screw with the finishing of the paint/
    97 Monte Carlo
  12. #12
    Sep 2004
    25
    2,211
    17
    vinyl...nothing too flashy. i want to make it look like it belongs, and IMO, vinyl is most often the best for that.
  13. #13
    Feb 2004
    Midwest Ohio
    26
    3,509
    Quote Originally Posted by bcarpenterfhl
    Yea vinyl will look pretty good. How do you attach it though. Is it like a big sheet of and you stick it on. Also is it strecthy or do you have to sew it like at hard coreners such as you do cloth on seats. I jsut never really messed with it before. Just know how it looks.
    97 Monte Carlo
  14. #14
    Sep 2004
    25
    2,211
    17
    Quote Originally Posted by monte_carlo97
    it comes it rolls just like carpet. i believe you apply it the same way you would with carpet (3M 77, contact cement). it doesn't strect quite as easily as carpet, but i think i'll get away with just once single seam on the back of it.
    i need to choose a good ~7 inch screen now, suggestions anyone? $100-150 is my range.
  15. #15
    Feb 2004
    Midwest Ohio
    26
    3,509
    ic, Sounds like it will look pretty good.
    97 Monte Carlo
  1. Impals SS Work Log Thread Thingy (im sorry 56k)
    By Acidburn in forum General Discussion
    Last Post: 05-21-2005, 07:57 AM
  2. Want to learn make custom fiberglass work
    By mnjh94 in forum Enclosure Design & Construction Help
    Last Post: 01-13-2005, 09:07 PM
  3. Rear deck/seats fiberglass mount...which to do?
    By MetalMaxima in forum Enclosure Design & Construction Help
    Last Post: 12-13-2004, 06:13 PM
  4. New fiberglass work completed
    By dbornotdb in forum Enclosure Design & Construction Help
    Last Post: 09-27-2004, 08:07 AM
