Results 1 to 4 of 4
Reload Thread: Check box plans please.
    gr3nade's Avatar
    gr3nade is offline Member
    Feb 2005
    Nuevo, CA
    63
    Can anyone check out my box plans and make sure that it's tuned right. I took away 1.5" for port end correction. Thanks.
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    26
    3,614
    Re: Check box plans please.
    your 29.75 measurement is off, you forgot to subtract the 1.5" on the other side of the port as well. also, if you add together all of the dimensions inside the box, you will come up with 38.75" wide. the 9.5" is also off.
    gr3nade's Avatar
    Feb 2005
    Nuevo, CA
    63
    What about now? I put everything into the port calculator and got 32.5Hz. Which is really close to what I was going for.
    Thanks
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    27
    15,432
    21
    what you need to do is get Autocad.
    then just draw whatever you have there in, and if it dosnt come out right, you will be able to see why. basically its like using a ruler and drawing 'a scale model' of the box on paper first.. and making sure it all fits.
    id look into some form of CAD
  1. box and port calculation review
    By derek33 in forum Enclosure Design & Construction Help
    Last Post: 02-06-2005, 02:21 PM
  2. Port calculation
    By monte_carlo97 in forum Enclosure Design & Construction Help
    Last Post: 02-03-2005, 09:34 AM
  3. check out this is it possible for a port like this
    By dumbguygeorge in forum Enclosure Design & Construction Help
    Last Post: 01-27-2005, 08:06 PM
  4. port bend question
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 11-01-2004, 08:06 AM
  5. J-
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 01-06-2003, 03:50 PM
