Page 1 of 2 1 2 LastLast
Results 1 to 15 of 17
Reload Thread: Could someone design me a box?
    walterdixon's Avatar
    walterdixon is offline Member
    Oct 2004
    Ontario, Canada
    86
    Hey, I have a Koda 10 that needs a home.
    Box will be ported, ~1.5 cubes tuned to ~33HZ. (can be a little bigger smaller if need be).
    Space isn't much of an issue, although, I'd like to keep the hieght down as low at 11" if possible, and not too deep (making up for it with width).
    I would like it to be slot ported as well.
    I am willing to send the designer a bit of $$ via paypal...
    Thanks in advance.
    '95 Nissan 240sx LE
    Headunit - Clarion DXZ745MP
    Components - Aura MR62
    Rear fill - JL TR650CXi
    Comp/Sub Amp - Memphis 16-ST3004
    Sub - Adire Audio Koda 10
    1.5 cubes tuned to 32hz
    Wiring - KnuConceptz
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    26
    3,614
    Re: Could someone design me a box?
    I can do it using 3/4" MDF it cant be any shorter than 10.75 inches though because the cutout is 9.25"
    mulisharider10's Avatar
    mulisharider10 is offline Low Co. Motives
    May 2003
    San Diego, Ca
    27
    278
    email me and ill send u a design and u dont even need to pay me.
    silverlightng@yahoo.com
    May 2003
    San Diego, Ca
    27
    278
    ****, u dont even have to email me, just could someone help me load a picture? i dont know how???
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    25
    2,211
    17
    Quote Originally Posted by mulisharider10
    check my sig out
    May 2003
    San Diego, Ca
    27
    278
    problem??? i browse to find the image, then, i click to select it, then i click host know, and alls i get is a blank screen. Whats wrong?
    Sep 2004
    25
    2,211
    17
    make sure its saved in jpeg format.
    May 2003
    San Diego, Ca
    27
    278
  9. #9
    May 2003
    San Diego, Ca
    27
    278
    if the pic comes out bad just click it and it will clear up so u can read the #'s
  10. #10
    Oct 2004
    Ontario, Canada
    86
    mulisharider10, i appreciate the design, thank you.
    one question though...how wide is the port? i see a measurement above the box of 1", is that the width of the port?
    '95 Nissan 240sx LE
  11. #11
    ngsm13's Avatar
    ngsm13 is offline BSEE
    Sep 2002
    Cincinnati, OH
    35,737
    20
    a one inch port won't work too well...
    You need AT LEAST 2" or so i'd say to prevent significant port noise!
    NG
    http://crunktimes.com/ct/
    nG - BSEE
  12. #12
    Bavarian3's Avatar
    Bavarian3 is offline Ownz joo
    Mar 2003
    Nor*Cal
    26
    5,170
    yikes...dont want to be using a 1" port...
    Upcoming SQ competition ready install...
    -Eclipse cd8053
    -Image Dynamics Cd1Pro MH
    -Image Dynamics 6.5" mids with CX motors and poly cone in custom fiberglass kick panels
    -12" Stereo Integrity Magnum in large sealed fiberglass wheel well enclosure.
    -Viper d1200.1 (sub), Viper 400.2 (mids), David Navone Amp-100 (horns)
  13. #13
    May 2003
    San Diego, Ca
    27
    278
    i have built many ported boxes for subs **** as jl w6v2's ans w3's , all with a 1" port. No problems. Id say a w6 would out run a koda. also, the other problem is that if u wanted the port in wider, the port would need to be double the length, which is really long
  14. #14
    May 2003
    San Diego, Ca
    27
    278
    if 2" is absolutly necisary, make the first part of the port wall 8.5", move it to the left an inch, then add 22"s to the 6.25" it will only be around 30 hrz then, but still, it will work.
  15. #15
    ngsm13's Avatar
    Sep 2002
    Cincinnati, OH
    35,737
    20
    ummm...you're going to totally have to re-design it...
    You have to:
    State a desire net volume
    Add port displacement to desired net volume
    Add driver displacement
    State the desire dimensions of two sides, then solve for the needed length of the third side using gross volume (net+port+sub disp)
    NG
    nG - BSEE
  1. Can Someone design a box for 5$
    By skeptikal in forum Enclosure Design & Construction Help
    Last Post: 12-14-2004, 10:10 PM
  2. Box Volume.
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 02-24-2003, 01:37 AM
  3. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  4. ATTN: Jmac!
    By MUGEN! in forum General Discussion
    Last Post: 12-31-2002, 04:42 AM
  5. Box design help
    By jinx8402 in forum Wiring, Electrical and Installation Help
    Last Post: 09-01-2002, 11:52 AM
