Results 1 to 7 of 7
Reload Thread: Vented enclosure question
    deadhead's Avatar
    deadhead is offline Junior Member
    Feb 2005
    Corpus Christi , TX
    17
    I am making plans to build a custom enclosure, up until now all I have ever built was sealed . I would like to build a vented but I have limited space , the local shop was not real helpful with this question.
    Can two subs share the space to come up with the needed 2 cubic feet. If so would I use only one port ?
    Nov 2004
    Rochester NY
    34
    663
    Re: Vented enclosure question
    how much dose each sub need for space? yes you can have 2 subs in one chamber as long as it is enought internal volume for both subs combined, minus the port, woofer, and bracing displacement.
    deadhead's Avatar
    Feb 2005
    Corpus Christi , TX
    17
    Each sub requires 2 cu ft , the plan I have so far only allows for 2.37cu ft
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    you are going to need 4 cubes for the subs alone, then you need to add in driver and port displacement
    deadhead's Avatar
    Feb 2005
    Corpus Christi , TX
    17
    thats the answer I didn't want but thanks for breaking my spirit, back to the drawing table I go.
    2004 Nissan Frontier "Desert Runner"
    Pioneer DEH-7600MP
    Pioneer TS-D160R 6.5"
    Pioneer GM-4000F
    Pair of Memphis PR-124D 12"
    Memphis PRD500.1 500w RMS @ 1 ohm
    Custom Enclosure tuned to 40hz
    XM Radio
    Viper 791XV
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    37
    4,234
    iso...1ft^3....
    don't really know how it would turn out i've never messed with it
    but its an option
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    nismboy6986's Avatar
    nismboy6986 is offline the **** technician
    Jul 2002
    Belhaven NC
    665
    and slot ports take up a lot of area themselves for my current situation it will need the same amount of air space if i added another sub. thats why i'm going to stick that bad boy on the outside.
    Car: '97 Crown Victoria P71
    HU: Pioneer Avic X710BT
    Front stage: want bravox CS603CF
    Front stage amp: want powerbass XTA 2240
    Substage: 15" FI BL fully loaded in 3.5 cubes @33hz firing through rear deck.
    Substage amp: Powerbass XTA 1500D
  1. Vented Enclosure
    By Phatillusion in forum Subwoofers
    Last Post: 12-18-2002, 05:29 PM
  2. Vented enclosure
    By Wkerat in forum Enclosure Design & Construction Help
    Last Post: 12-04-2002, 10:34 PM
  3. Enclosure Question
    By jester73440 in forum Subwoofers
    Last Post: 03-24-2002, 03:35 AM
  4. Hi, Another enclosure question :)
    By LuRp in forum Subwoofers
    Last Post: 02-23-2002, 12:35 AM
