Results 1 to 4 of 4
Reload Thread: HELP!!! Sealed Enclosure for Orion H2 12.2
    BringontheNoize's Avatar
    BringontheNoize is offline Junior Member
    Jan 2005
    Cinnaminson,NJ
    im trying to find dimensions to build a sealed enclosure for my Orion H2 sub i just bought. ive been looking around and i cant seem to find anything...i really need help..please help. thanks alot
    DFW40's Avatar
    DFW40 is offline CarAudio.com Veteran
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    Re: HELP!!! Sealed Enclosure for Orion H2 12.2
    what is the airspace recomended by manuf. and what type of car?
    Jan 2005
    Cinnaminson,NJ
    the recommened airspace for the H2 12.2 2500 watt sealed is .5 cu ft....im putting it in a 2001 Oldsmobile alero
    DFW40's Avatar
    Aug 2004
    Keller, TX DFW area
    44
    2,073
    11 Post(s)
    Go to this link here and scroll down to what shape enclosure you want and start plugging in numbers. Your wood thickness should be .75 and the rear or the sub probably takes up about .15 cubic ft. So you want your enclosure gross volume to be .65 or so. Play with the numbers on this site.....you will find it very easy. I think that the sub you have is pretty deep 7- 8 inches so remember that when you design your box.
    http://www.the12volt.com/caraudio/boxcalcs.asp#par
  1. ported and sealed enclosure
    By jr15 in forum Subwoofers
    Last Post: 02-26-2005, 03:14 PM
  2. Magnum Sealed enclosure questions
    By amedeuce in forum Enclosure Design & Construction Help
    Last Post: 02-25-2005, 01:29 AM
  3. Sealed Enclosure Calculations help
    By AznRevlAzn in forum Enclosure Design & Construction Help
    Last Post: 02-24-2005, 11:39 PM
  4. Is it possible to get the same quality of sealed bass in a ported enclosure?
    By electronicsgeek in forum Enclosure Design & Construction Help
    Last Post: 12-22-2004, 12:36 AM
