Just wanted to share this with all the serious box builders. This will significantly cut down on time spent fumbling with table saws and circular saws. Now you can be your own Home Depot.
http://www.southern-tool.com/store/p...panel_saw.html
HU: Sony Xplod MP80
Highs and Mids:
Infinity Kappa series 63.5i
Infinity Kappa series 572.5cf
Subs: (3) Incriminator Audio DP 15's
Sub amps: (2) Crunch GP3000D Pro's
This one is ridiculously LOUD!
References: Bamaboy, AZ-ss, 9512ds, and DRCKISS
I've got a link somewhere (i'll look for it later) on how to build your own. And it isn't that difficult or expensive
cool. There are definitely advantages to both panel saws.
HU: Sony Xplod MP80
Highs and Mids:
Too expensive to justify unless you're in business. My method is to get the full sheet cut into manageable pieces at the source, then trim to size with my table saw. $800 will get you one dandy table saw, with extension and super fence.
dave
1999 Buick Park Ave Ultra
Head Unit: JVC KWHDR720
EQ: Audiocontrol EQL
Front Stage: Hybrid Audio Technologies Imagine 5.25
Sub Stage: In process (will be Boston G310)
Amp: Boston Acoustics GTA-704 4 Ch
Rear Fill: Boston SE953 6X9's
You're right, 800 will get you a nice table saw.Originally Posted by maylar
all u need is a circular saw, 2 c clamps, and a piece of molding. set the jig on the line to cut and run the saw down it. its easy, and cheap to cut perfect lines.
Why dont you just cut it into approximate sizes with a circular saw and then straighten the edges with a table saw? Youd only waste about .5 sqft of scraps if you have alot of cuts...and even then you could mash em up and use for sealing.
Take off every 'sig.
exactly, works just as good, all you have to worry about is keeping the circular saw against the molding which is easy, and takes only 1-3 min to setup tooOriginally Posted by analogkid
and oh the portability!
Bookmarks
