Results 1 to 4 of 4
Reload Thread: Need help with box for 2 12" RE SX's
    awinter's Avatar
    awinter is offline Senior VIP Member
    Dec 2004
    Chandler, AZ
    258
    I am building a ported box for my 2 12" RE SX's. The have a template for the box at http://www.reaudio.com/html/enclorsure.htm . I would do the dual ported box of course but i was wondering what SQL was. it has two options SQ and SQL. I know sq is sound quality and i thought spl was sound pressure level then what is SQL. also can i get some help on tuning it 3hz lower than that box says because thats a 35hz and mine is optimal at 32hz. Can someone please help me out thanks
    02 White Diamond Escalade
    Alpine IVA-D300 Head Unit
    Audiovoxx 15.2" Flip Down Monitor
    2 7" Ultravision Headrest Monitors
    Boston Pro60's in the Front
    Boston SX65's in the back
    Rockford Power 4004 for the speakers
    2 12" RE 2006 XXX's
    2 Orion WCC-5000d's (New Orion 2500d)
    2 Yellow Top Optimas
    Dual Alt Bracket with 2 275 Amp Alternators
    Soundstream 40 Farad Cap
    Sub box: ~11 cubes 4th order bandpass tuned to hit from 20-80 Hz(I <3 Bandpasses)
    120 sq ft of eDead
    Have 1 Blown RE SX and 1 SX In Great Condition
    Also have 2 2 Rockford Power T10001BD amps that are only 1 month old LMK if youre interested
    Cardomain Site
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    26
    3,614
    Re: Need help with box for 2 12" RE SX's
    SQL is inbetween SQ and SPL, its a mix of both. tuning to 35 hz will give you a good deal of output and it will still sound nice. 32 hz may not meter quite as high, and it will probably have a bit flatter response.
    InhumanAcura's Avatar
    InhumanAcura is offline 1/3ofTEAM PwNAGE..*****es
    Feb 2004
    South Florida
    8,620
    5 Post(s)
    That SQL box was the first ported box I built Got loud and sounded good with my Inhumans...
    awinter's Avatar
    Dec 2004
    Chandler, AZ
    258
    what do you recommend i tune it to for max spl. I dont care for SQ as much as i care for SPL but i dont want it to sound horrific
    2 12" RE 2006 XXX's
    120 sq ft of eDead
    Cardomain Site
  1. box too small for 2 12" L7's?
    By dkguitarist in forum Enclosure Design & Construction Help
    Last Post: 12-01-2004, 06:11 PM
  2. Help-- Box for 2 12" Incriminator LI's??
    By big mike 13 in forum Enclosure Design & Construction Help
    Last Post: 10-02-2004, 05:35 PM
  3. Box for 12" w7?
    By Kinalyx in forum Enclosure Design & Construction Help
    Last Post: 01-15-2003, 10:33 AM
