Results 1 to 12 of 12
Reload Thread: Calculating Cu.ft. In Fiberglass
    chevy6998's Avatar
    chevy6998 is offline Senior VIP Member
    Jan 2005
    FAWN GROVE, PA
    193
    Here Is A ?. How Would You Calculate The Area Of A Sealed Fiberlass Enclosure (for Subs) With An Ambiguous Shape, Its Not Like You Can Break It Down Into Sections And Calculate It, Its All Convex And Concave Curves!!!! I See All These Crazy Ameoba Shaped Enclosures And I Wonder How They Calculated The Area To Match The Subs Requirements
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    32
    7,848
    Re: Calculating Cu.ft. In Fiberglass
    I always say sand or water... more accurate the packing peanuts.
    What the f00k happened to this place?
    chevy6998's Avatar
    Jan 2005
    FAWN GROVE, PA
    193
    Quote Originally Posted by NjccBflo
    GOOD POINT, BUT THATS ONLY GOOD IF THE MAGICAL SHAPE YOU CHOOSE JUST BY LUCK HAPPEN TO MEASURE OUT OK, MY REAL FOCUS IS IN THE PREDESIGN, ITS NOT GOOD IF YOU BUILD IT FILL IT FULL OF WATER AND THEN FIND OUT ITS A RIDCULOUSLY USELESS DESIGN, ALSO WATER DOESNT WORK IF ITS ALSO PARTIALLY MDF!!!
    Nikuk's Avatar
    Jul 2004
    Buffalo, NY
    32
    7,848
    Quote Originally Posted by chevy6998
    {CAPS LOCK}
    Best to build too big and back fill it. You get the hang of "guestimating" after the first couple of projects.
    -and-
    Thats why SAND is always an option.
    Nitropyro666's Avatar
    Nitropyro666 is offline Pimping a Stro'
    May 2004
    Columbus, Ohio
    26
    164
    First you asked he answered dont sound so mean in you reply.
    second you should have a rough design build it a tad big then you can add small junks of wood to make it the right size. if it happens to be too small add a little polyfill.
    third good luck and its not an exact science sort of guess and checkl
    Danny
    Who-Danny Allen 18 years old
    Ride-89 Chevy Stro'
    Important stuff
    Stereo-Alpine 7977
    front-Infinity Reference 6000cs 6.5" components
    rear-infinity 4x6 plate speakers
    amps-directed 1200/5 (for comps)and a directed 1100d (for sub)
    sub-Re Se 12"
    wiring-Scosche 4ga have 2ga ready to install
    AIM-nitrpyro
    Yahoo-nitropyro666
    chevy6998's Avatar
    Jan 2005
    FAWN GROVE, PA
    193
    Quote Originally Posted by Nitropyro666
    Danny
    sorry not being mean, im just short and to the point, didn't realize how it sounded till i read it the second time, i apologize
    chevy6998's Avatar
    Jan 2005
    FAWN GROVE, PA
    193
    i just thought there may be more o f a science to it
    Nikuk's Avatar
    Jul 2004
    Buffalo, NY
    32
    7,848
    there can be. Whoa there can be.
    But... You (and alot of others on this forum) should realize that, unles you are very seriously competing then:
    -If your tuning is 1.03hz off, it's not the end of the world.
    -If your vB is off 0.0000786^cu ft, it's not the end of the world.
    -If your SSF isn't dialed in exactly right, your woofer will not launch it's cone.
    -Nick
  9. #9
    chevy6998's Avatar
    Jan 2005
    FAWN GROVE, PA
    193
    -Nick
    Theres and exact science to just about any thing, but most of the answers I got were guestimation solutions. if you know any sites or books on the subject let me know
  10. #10
    Damaso87's Avatar
    Damaso87 is offline iPoor
    Oct 2004
    Springfield, MA
    918
    You dont want to get yourself into it...its much more complex than just plugging numbers in.
  11. #11
    gunny86's Avatar
    gunny86 is offline Member
    Aug 2002
    wi
    126
    Well yeah there is an exact science to this too, just simply build it and plan on it being large, figure how much air space there is when you are done, now look at your numbers, you needed 1ft^3 you are at 1.1, 1.5, or 1.9549349, it doesnt matter which, now just add the correct amount of filling and your done, it doesnt take long at all and it isnt too hard. Sorry if i come off rude im not trying to be at all im just laying it out for you.
    correct my fellow audio enthusiest.....u officially owned someone...good job! -Saywhat?
  12. #12
    bonesninja's Avatar
    bonesninja is offline CarAudio.com Veteran
    Oct 2004
    Lima, Ohio
    40
    14,802
    there is another way---if you have the room. you simply build the enclosure out of mdf to the right specs and then use fiberglass purely as cosmetics to fit the contour of the space you want it to go into.
    Quote Originally Posted by chase007 View Post
    if u need a box...I'l taked 3 years of shop class so i know what im doing.
    after i explained to him there's more to a proper box than boards and glue and he should practice before trying to sell boxes to others
    yes personaly if it was some one elce that just starting making boxes but i'v taken shop for 3 years now...Making a lil box is nothing i don't need to pratice on a box to get it right i learned alot of stuff from 1 box and i can fix that in my next box
    after i told him that customers would care about the looks of the box
    if u want some thing that looks pretty why don't u find a black guy with a big d*ck.
  1. Combining Fiberglass Pieces
    By djXternal in forum Enclosure Design & Construction Help
    Last Post: 01-03-2005, 11:45 PM
  2. Question about Fiberglass
    By Zacmc212 in forum Enclosure Design & Construction Help
    Last Post: 11-03-2004, 07:01 PM
  3. new fiberglass box question
    By badboyzx2 in forum Enclosure Design & Construction Help
    Last Post: 12-30-2002, 02:44 PM
  4. fiberglass ported
    By jjoven1225 in forum Enclosure Design & Construction Help
    Last Post: 12-25-2002, 04:38 PM
  5. Building Fiberglass enclosure
    By Atvnut2065 in forum Wiring, Electrical and Installation Help
    Last Post: 06-17-2002, 05:04 AM
