Results 1 to 14 of 14
Reload Thread: 4 tenzzzzz
    Oct 2004
    michigan
    490
    1 Post(s)
    4 tenzzzzz
    Sup guys, i have 4 10" mtx 8000's i had for about a month and finally decided to make a box for em. i have a directed audio 1100d amplifier for now. i have a 92 bonneville, decent size trunk. i never build a box before so dont really know what would be best,
    i could go with this design below (By brandont), is this a good box?
    please give me advise/suggestions thanks,
    bcarpenterfhl's Avatar
    bcarpenterfhl is offline Kiss Me I'm Shitfaced
    Sep 2004
    San Francisco/Hillsborough, CA
    30
    2,211
    17
    Re: 4 tenzzzzz
    awsome box he built. he used some pretty complex bracing though. also the sub direction isnt the best; should be faced towards rear. def. on of the better boxes i've seen.
    TimberJon's Avatar
    TimberJon is offline Member
    Feb 2004
    LA, CA
    136
    Re: 4 tenzzzzz
    Um im an Engineer, and I dont see ANY bracing.. The red-like lines are center point referances for the dimensions. I only see one port. Nice port, but Id use two of them for 4 subwoofers. Try to get the box built so - like bcarpenter said - the subs are facing rearward, and the ports point in the same direction as the subs. One on each side of the box.
    Ive even seen UPward facing ports, in SUVs.
    theCybe's Avatar
    theCybe is offline sector three
    Dec 2004
    Columbus, OH
    6,004
    Re: 4 tenzzzzz
    I threw 3 of those subs in an enclosure with the same exterior dimensions as the diagram above; It's sealed, and the subs face rearward; I'm not satisfied. That, and the box blew apart. The box is way larger than it seems in the diagram, heavy as $#!t, and ultimately insufficient; I'm porting mine when the weather dries up, and retacking the lid.
    So brace it. : )
    I wonder how Brandon's is holding up.
    TimberJon's Avatar
    Feb 2004
    LA, CA
    136
    Re: 4 tenzzzzz
    L00ks like itd fly apart.. not enough port space. And i wouldnt seal a box with more than 2 subs in it. As far as the bracing on more than 2 subs.. extreme, my boxes are HUGE because of the amount of displacement inside. But solid like Dreadnaughts.
    cobra65427289's Avatar
    cobra65427289 is offline CarAudio.com Veteran
    May 2003
    IL
    31
    2,341
    Re: 4 tenzzzzz
    not a bad design. if you want SPL i would shoot for 6 cubes, 120 sq inches of port area, good place to start. if you want some bump, keep your current design. not bad.
    al
    Fact 1: 79,000,000 people are engaged in intercourse right now.
    Fact 2: 58,000,000 are kissing.
    Fact 3: 37,000,000 are relaxing after having *** .
    Fact 4: 1 lonely bugger is reading forums...- You hang in there sunshine!
    Sep 2004
    30
    2,211
    17
    Re: 4 tenzzzzz
    IMO, the port area isnt too bad. i have a box thats about the same size, and the only thing supporting it is a wooden dowel and the port. i jumped on it, and it doesnt flex the slightest. i think brandont knew what he was doing....
    mrray13's Avatar
    mrray13 is offline uz some fegbags
    Dec 2001
    IL
    3,633
    Re: 4 tenzzzzz
    Quote Originally Posted by cobra65427289
    al
    ^^x2..this box design is sufficient. if u have any concerns...maybe put some 3/4" dowel rod in between each sub, top to bottom....
    other then that...that's a decent box...should be fine.
    wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
    Quote Originally Posted by lilmaniac2
    Your circles look like something a HMO doctor would do to a **** job ....
    ^^^ speaking about cbfryman's jigsaw ability
    owner of Thread posts 11111 & 12345
  9. #9
    SPLguy420's Avatar
    SPLguy420 is offline Pimp
    Oct 2004
    michigan
    490
    1 Post(s)
    Re: 4 tenzzzzz
    i posted this in a different forum and they said i should really try and get subs to fire backwards, instead of up. i cant fit 4 like this but i could prolly fit 3, do you guys think 3 subs firing backwards would be better then 4 firing up?
  10. #10
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,449
    11 Post(s)
    Re: 4 tenzzzzz
    Why not go sealed? Give each a cube.
  11. #11
    theCybe's Avatar
    Dec 2004
    Columbus, OH
    6,004
    Re: 4 tenzzzzz
    Quote Originally Posted by bcarpenterfhl
    Yeah, but pressure from the inside of the box is a different story; Ask my [torn-up] box.
  12. #12
    Sep 2004
    30
    2,211
    17
    Re: 4 tenzzzzz
    Quote Originally Posted by SPLguy420
    how about three firing back and one firing up. i think the drvier depth is shallow enough.
  13. #13
    SPLguy420's Avatar
    Oct 2004
    michigan
    490
    1 Post(s)
    Re: 4 tenzzzzz
    wont that cause cancelation?
  14. #14
    Sep 2004
    30
    2,211
    17
    Re: 4 tenzzzzz
    i'm not really to sure. i think it would be less of an issue if you staggered them a little bit, so they arent all aligned.
