Results 1 to 6 of 6
Reload Thread: Confused on box Specs:help:
    MED's Avatar
    MED
    MED is offline Junior Member
    Sep 2004
    Charlottetown,P.E.I.
    I am in the process of Building A New Ported box for my 2 Rockford Fosgate P312D4 Subs.
    I was going by the Spec Sheet and putting it into the WinISD prgram so it will give me Volume and Size for the Box.
    So I also checked the Rockford Fosgate website and they were telling me a totally Different Size and Volume.
    What should I go by?
    gunny86's Avatar
    gunny86 is offline Member
    Aug 2002
    wi
    126
    Re: Confused on box Specs:help:
    i would say just go with what rockford says.
    correct my fellow audio enthusiest.....u officially owned someone...good job! -Saywhat?
    MED's Avatar
    MED
    Sep 2004
    I was thinking the Same thing but I wanted input from someone else with more experience than I have.
    gunny86's Avatar
    Aug 2002
    wi
    126
    ok, rockford says 1.3ft^3 per sub tuned to 32hz. so with those specs you are up to 2.6cf, and after displacements you will be building a box over 3cf. so if you can spare the room and want somthing else i would say build your box so the subs will be seeing about 2cf each.
    4cf for the subs plus displacements your looking at somthing over 5cf i would think. so just make sure you have enough room( also make sure the box will fit through the trunk opening, just because it will fit in the trunk doesnt mean it will get past the tunk opening, i made that mistake once). what kind of car do you have?
    MED's Avatar
    MED
    Sep 2004
    It's going in a Pontiac Sunfire.
    Thanks for the help on the Box Specs.
    gunny86's Avatar
    Aug 2002
    wi
    126
    no problem, sorry but i have never worked on one of those so i really cant help much for the dimensions, the best way to start it is just go out and measure to see what you can fit.
  1. Designing a ported box with George
    By IgnoreMe in forum Enclosure Design & Construction Help
    Last Post: 06-03-2005, 07:18 AM
  2. Box Builders look
    By KARLEON in forum Enclosure Design & Construction Help
    Last Post: 11-20-2004, 02:17 PM
  3. Re8 box plans
    By sampson in forum Enclosure Design & Construction Help
    Last Post: 11-19-2004, 08:58 PM
  4. My 13kv2 ported box! (pics)
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 11-18-2004, 09:31 PM
  5. Ported Box for Kicker 12'' L7
    By F150Matt in forum Wiring, Electrical and Installation Help
    Last Post: 07-05-2002, 02:03 PM
