Page 1 of 2 1 2 LastLast
Results 1 to 15 of 18
Reload Thread: Round ports w/ port noise or slotted vent?
    pacho's Avatar
    pacho is offline Member
    Jan 2005
    S.C.
    124
    I'm constructing a box for a Treo 18" SSX sub. The box is 5 cubic feet and being tuned to 35 Hz with 50 in^2 of port area. I was wondering if I use 10 round ports (3" Diameter by 5" length), will I have a lot of port noise and will the sub sound bad b/c i've never used round ports before. Or do you recommend I use a slotted port?? Thanks.
    iceteebone's Avatar
    iceteebone is offline Banned
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    Re: Round ports w/ port noise or slotted vent?
    well i'm not a box expert but i hear round ports have more of a tendency to create port noise and with a slot port box you would have more port area.
    pacho's Avatar
    Jan 2005
    S.C.
    124
    Is there any way I could solve the port noise problem by using aeroports?? I could use 4 aeroports but then I have to have some more port area, maybe add one 2" Diameter X 4" Length round port w/ the aerports?
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    i heard that the bigger the diameter the less chance of port noise. also i hear putting sound deadener on the port reduces port noise.
    pacho's Avatar
    Jan 2005
    S.C.
    124
    I heard once that there's a way to round the edges of the port or something which will reduce port noise, is there any truth to this?
    iceteebone's Avatar
    Aug 2003
    Michigan
    28
    37,907
    3 Post(s)
    Quote Originally Posted by pacho
    that's what i heard on slot ports when they make a bend inside the box.
    hoss's Avatar
    hoss is offline imma genius. so **** it!
    Sep 2003
    inside icetee, while he is inside seths sister
    29
    13,817
    slot ports and round ports work exactly the same way. the only difference between the two is the shape. if you have the same port area figured, you have just as much likelyhood for port noise in each case. i myself would prefer the slot port just because of the fact that it is slightly easier to design and build. as for port noise though, that is totally dependent on the port area, and not the port type.
    rounding the edges in the box will help a good deal. reduces air turbulance and makes a better path for the air to oscillate within. good for a tenth or two on the mic, and yes, it could help prevent port noise
    pacho's Avatar
    Jan 2005
    S.C.
    124
    I'm probably going to go with the 10 round ports. If anyone can check my calculation-I would appreciate it. One round port is 3" Diameter X 5" length. Pie*r^2*h=inches^3. I want 50 inches ^2 of port area so I believe that would be 353 inches ^3. Pie*1.5^2*5=35.34 inches ^3 for one port. So that would mean I would have to use 10 round ports of 3" X 5" to equal 353 inches ^3 of port area?? Thanks.
  9. #9
    pacho's Avatar
    Jan 2005
    S.C.
    124
    Can anyone check my calculations??
  10. #10
    pacho's Avatar
    Jan 2005
    S.C.
    124
    Bump:
  11. #11
    pacho's Avatar
    Jan 2005
    S.C.
    124
    I'm going to point the sub up in my car and I'll fold the seats down, but I'm deciding whether to face the port in the passenger area or towards the rear of the car. Anyone know anything about this?
  12. #12
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    26
    3,614
    IMO a slot port is a better idea than 10 round ports... and id give it more like 100 sq in of port
  13. #13
    mobileaudio219's Avatar
    mobileaudio219 is offline Senior VIP Member
    Dec 2004
    Central, Missouri
    318
    If you fire the subs forward into the cabin then you can't put the ports firing back towards the trunk... Why not use a bigger diameter pipe (5.51") and use a just a couple of ports?
  14. #14
    mrray13's Avatar
    mrray13 is offline uz some fegbags
    Dec 2001
    IL
    3,633
    and u don't figure the length into the equation....a 3" round port has 7.06in^2 of port area..
    so for 50in^2 of port, u will need (7) 3" round ports or one 2x25, 5x10, 3 3/38x15...yada yada yada ..slot port...
    the length determines tuning...and multipling it in determines port volume, not area
    wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee eee
    Quote Originally Posted by lilmaniac2
    Your circles look like something a HMO doctor would do to a **** job ....
    ^^^ speaking about cbfryman's jigsaw ability
    owner of Thread posts 11111 & 12345
  15. #15
    pacho's Avatar
    Jan 2005
    S.C.
    124
    Alright, so instead if I wanted to use (4) 4" Diameter X 5" length round ports, would my box be tuned to 35 HZ or what equation can I use to calculate tuning freq? Mrray, wouldn't you have to put the length in the equation because to tell the difference between a 12" length aeroport and a 5" length that I'm using? And mobileaudio-I'm going to be pointing the sub up in my trunk and the ports firing into the passenger cabin with the seats down. Would this still sound as good as pointing the ports towards the rear of the car?
  1. building a ported box with a round port question...
    By g30ffr3y in forum Enclosure Design & Construction Help
    Last Post: 12-20-2004, 08:59 PM
  2. subs that people will hear
    By Big-Cat in forum Subwoofers
    Last Post: 09-17-2004, 01:42 PM
  3. J-
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 01-06-2003, 03:50 PM
  4. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  5. how can i get rid of the car noise?
    By Grand Am in forum Wiring, Electrical and Installation Help
    Last Post: 05-31-2002, 07:47 AM
