I was just going to use industrial staples, but since im going to home depot tommorw, i figured i might pick up somethin better.
What do you all use to adhere the carpet to your sub boxes?
oh btw its the end of the month... watch out![]()
Computer/Audio in Car Install:
{=====-----} 50%
MS-6714 mATX, Celeron 2.8ghz 400/128, 512 PC2700, Mini Keyboard,
Touchpad, Gps Mouse, Opus SFX12v 150w, Lilliput Vga Touch 7"
Custom Lockbox Case, usb dvd drive,
A8000T, AW1500Q, MRP-F240, 4x Pioneer 6x8s
Currently Building box for sub, installing amp/sub and 4channel amp
Door speakers installed.
"Gee, I hope everything came out with me."
spray glue...
yup, the stuff that comes in the aerosol cans.Originally Posted by Moe Lester
JOIN teamSSAudio.com
alright thats easy enough then. Any particular brands, the only spray adhesive i ever see if for paper and such. Do you get it at home depot / target / kmart , where ? Thanks
{=====-----} 50%
argh, since it was already answered...
I've found it at all those places...Wal-Mart, K-Mart, Lowe's, Home Depot...
pretty common item.
thanks
{=====-----} 50%
spray glue, make sure you spray on then let sit for like 45 seconds then put on then put weight on it, that works best for me
I like contact cement.
3M-77 or 3M-90. Contact cement would also work, but for a large job spray adhesive makes much more sense.Originally Posted by RogerWilco
"The world is full of people who want nothing short of perfect,
but settle for less, blinded by their quest for purpose."
- Slug
3M spray adhesive. As vossch said spray both surfaces, let it tack before attaching, and it'll never come off.
i gave up on spray adhesive... ive moved on to using a
hot glue gun... it works awesome and is less of a mess
than the spray glue which kinda ***** at sticking...
___________________________________________
my setup
2004 honda accord V6 EX / Nighthawk Black Pearl 2 door coupe
premier 860 / eD 16Ov.2 / viper 1200.1 / 2.2^3 @ 30hz / stinger bullet interconnects
girlfriends setup
2004 pontiac sunfire / silver metallic / 2dr coupe
eD e12o.44 / memphis 1000d / 1.6^3 sealed box
here we are
face to face
same energy
you and me
dont want to be
enemies
references:
kevin85193
JAZN
swimfreak26
DAPs contact cement.. my dad is a union carpet layer and thats what he always tells me to use.. and hes been doing carpet for 31 years so i trust himu can pick a can up at lowes and probaly home depot.
oh if u use this.. dont get the gel.. and apply it to both the carpet and the box...this stuff has a very strong odor so make sure this is done outside... let it dry for a day too or ur car will stink like it.... after u let that cure i garauntee ur carpet wont come off and will look good.
Headunit: Pioneer AVH-P2300DVD
Subwoofers: (2)15" RE Audio XXX(05 model)
Sub Box: Undecided..
Sub Amp: Crescendo bc3500
Speakers: 6.5" RE Audio XXX Components(soon to be 2nd pair in kick panels)
Speaker Amp: Hifonics HFi100.2(for now...)
Wiring: 2 runs of 1/0 throughout, XS Power battery in trunk,big 3 done, 270a alt, 1/0 accesories throughout
Deadner: 75sq ft AT 60mil, 20sq ft Alphadamp
Security: Crimestopper 2way alarm/remote start
You must be doing something wrong, 3M-77/90 stick very, very well.Originally Posted by g30ffr3y
- Slug
Originally Posted by Gauntlet
well glue isnt really that hard to use... so i dont know what
i could be doing wrong exactly...
the nearly instantaneous bond and control of the hot glue
must just suit me better...
my setup
girlfriends setup
here we are
face to face
same energy
you and me
dont want to be
enemies
references:
kevin85193
JAZN
swimfreak26
Well you're definitely doing something wrong, they make a very strong adhesion. It's sort of similar to contact cement, you have to spray both sides fairly generously and wait at least a minute before you adhere them to each other, otherwise it won't work.Originally Posted by g30ffr3y
- Slug
Bookmarks
