Results 1 to 8 of 8
Reload Thread: Calculation check
    Puggsley456's Avatar
    Puggsley456 is offline Who said you could talk?
    Apr 2003
    WPG>MB>CAN
    479
    Calculation check
    I trying to design a box for my ed 16Kv.2 (14 inch mounting hole needed)that I am ordering. Now I have height restrictions in my trunk so this is what I got sofar. The rectangle box will be 16 inches high, 12 inches deep and 29 inches wide using .75 inch mdf.
    Internal volume after subtracting (.08 Ft^3 )subwoofer displacement is 2.34296 Ft^3.
    I am going to use a 3 inch round port. I dont know if this is right but I figure in this setup I will require a 6.84197 inch long port.
    Can someone verify if I am correct with these? Because I used some online calculator and I dont know if I should trust the numbers.
    Any ideas or concerns with this setup?
    - 99 Cougar -
    - Rainbow CMX265 Kickbass - PG ti600.2 -
    - Mach 5 Audio (2) IXL12's in 3.2 cubes [email protected] 33hz - USAmps MD.1D -
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    Re: Calculation check
    If you use a 3" round port you are going to have a TON of port noise... you need 2 4" ports at the LEAST. Why not build a slot ported box?
    Apr 2003
    WPG>MB>CAN
    479
    I just thought ithat if i use a round port as aposed to a slot port I will be able to keep the box size smaller.
    If I redo the calculations with 4 inch ports as you say. Do I just cut the required length in half devided between the two ports? And is port placement an issue?
    - 99 Cougar -
    Apr 2003
    WPG>MB>CAN
    479
    using the same dimensions, going for a 30Hz tune it says to use 13.13428 inches of 4 inch port or roughly 13 and 1/8 inches of total port length for a box that is 2.34296 ft^3.
    - 99 Cougar -
    Apr 2003
    WPG>MB>CAN
    479
    - 99 Cougar -
    Moe Lester's Avatar
    Dec 2003
    Houston, TX
    31
    3,614
    if you go from 1 4" port to 2 4" ports, you are gonna have to increase the length by alot on each port. The ports will probably need to be much longer than the box is deep, a slot port is probably your best option.
    DeepMag1c's Avatar
    DeepMag1c is offline Member
    Feb 2004
    Jackson, MS
    33
    141
    is there a calculator that does slot ports like this one does round ports?
    Vehicle: 1988 Chevy Suburban
    Head Unit: Alpine 9827
    Front Speakers: Massive Audio PX6s
    Rear Speakers: Massive Audio PX6s
    Stage AMP: Uknown(comming soon)
    Subwoofers: 2x 15"XXXs (comming soon)
    Subwoofer AMP: Orion 2500D (comming soon)
    Damaso87's Avatar
    Damaso87 is offline iPoor
    Oct 2004
    Springfield, MA
    918
    Quote Originally Posted by DeepMag1c
    Yes, its right here http://www.caraudio.com/vb/showthread.php?t=68635
  1. Check this out, give us feedback please.
    By audiofanaticz in forum General Discussion
    Last Post: 11-07-2004, 11:27 PM
  2. Check Out My Box Plans
    By tmaggert in forum Enclosure Design & Construction Help
    Last Post: 09-22-2004, 12:12 AM
  3. Replies: 1
    Last Post: 10-03-2002, 05:23 PM
  4. subs.. check.. amp... check.... wuts next???
    By chinxtaboi in forum Subwoofers
    Last Post: 09-04-2002, 11:16 PM
  5. insurance check in the mail - FINALLY!
    By ssimpalass95 in forum General Discussion
    Last Post: 02-16-2002, 08:35 AM
