Results 1 to 3 of 3
Reload Thread: How do you suggest I build this?
    CONSOLIDATED's Avatar
    CONSOLIDATED is offline Where I'm From.
    Aug 2004
    VA
    141
    I'd rather do fiberglass, though I've never done it before, I'm pretty sure I'd be able to.
    1st problem is my limited space. Yeah, I have a pretty large trunk, but I'm not gonna cover up the spare tire well. I can go about 1/4 the way over it, but no further. I have to be able to get to that tire when I need to.
    Taking out the back seats is also not an option. I bought a sedan because I use the rear seats and back doors.
    What I think is the best option (with limited knowledge) would be to take out the mat (taken out for the picture) and cutting the plastic-carpeted floorboad in half. I could put it on a hinge, then put the mat back over it. That way, I can 'glass the back half, and still be able to open up my trunk when I need to.
    The second problem I have with fiberglass is what happens when you want to upgrade your subs, amps, etc.? Do you tear it down and start over?
    Lastly, how the hell are you supposed to measure a fiberglass enclosure?
    Pictures of trunk and wheel well:
    I know you know what a trunk looks like, but maybe some specifics are needed for someone that can help.
    Freedom Plaza or Bust
    Aug 2004
    VA
    141
    Re: How do you suggest I build this?
    Ok, I'll probably stick the enclosures all the way against the rear-bumper side of my trunk facing towards the back seats, provided I can find a way to fit the space 2 RE SE 10's need before I cover up the wheel well.
    One other thing about my hinge idea. If this enclosure facing the rear seats covered up a bit of the wheel well and I had the floorboard on a hinge, could I just lower my backseats and take the wheel out that way so I can utilize more trunk space for my fiberglass?
    Aug 2004
    VA
    141
    This place is a lot of help.
    Thanks.
  1. Time to help me build!!!
    By kjwiehoff in forum General Discussion
    Last Post: 10-14-2004, 12:10 AM
  2. Help Me Build My System
    By nathanh32 in forum Subwoofers
    Last Post: 01-11-2003, 12:42 AM
  3. Replies: 3
    Last Post: 10-05-2002, 02:52 PM
  4. how do i build a tuned box? or a abc box?
    By Unregistered in forum General Discussion
    Last Post: 02-09-2002, 11:33 PM
