Results 1 to 6 of 6
Reload Thread: Box plans. Correct? JMAC u out there?
    JoseMCeee's Avatar
    JoseMCeee is offline $tack
    Sep 2004
    Bay Area, CA
    2,250
    This is going to be with .75 mdf wood. 2.3^3 @ 32 hz.
    26 width x 14.5 height x 14 depth.
    Port lenght of 29.75. It will go 11.5 in toward the back of the box, then 18.25 toward the side of the box.
    Is this right?
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    Re: Box plans. Correct? JMAC u out there?
    29.16x13.5x15 (wxhxd)
    Port: 12x2.5 (heightxwidth) = 30 sq in
    29.75 inch port lenght
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    sound good? I might want to take off a little on the depth because and add it to the width, ima try that now...
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    32x13.5x13.7 Thats the same amount or cube ft.
    What ft^3 would it be with 32x13.5x13.5 after taking into acount the thickness and all the other stuff?
    brandontw's Avatar
    brandontw is offline just some guy
    Feb 2004
    Reno, NV
    32
    3,112
    2 Post(s)
    you can calculate it..dont be lazy
    JoseMCeee's Avatar
    Sep 2004
    Bay Area, CA
    2,250
    well im not sure how to factor in the driver displacement and port displacement. By the way Jmac hit me up on aim if you can
  1. Box plans for 2 Alpine Type R 12's
    By almost2asian in forum Subwoofers
    Last Post: 10-08-2004, 02:24 AM
  2. Need box plans..
    By avs20 in forum Enclosure Design & Construction Help
    Last Post: 10-02-2004, 06:18 PM
  3. JMAC, box I built for 10w3v2
    By JoeM in forum Amplifiers
    Last Post: 01-19-2003, 09:38 PM
  4. jmac need box help bad
    By millinivation in forum Enclosure Design & Construction Help
    Last Post: 01-18-2003, 11:27 AM
  5. JMAC is the man i need to talk to- HX2 box
    By mwess in forum Enclosure Design & Construction Help
    Last Post: 01-06-2003, 10:35 PM
