Page 1 of 2 1 2 LastLast
Results 1 to 15 of 16
Reload Thread: Fiberglassing headliner...
    bigwheel15's Avatar
    bigwheel15 is offline Ooh Yeah!!
    Jan 2004
    Fort Worth,Texas
    25
    3,761
    21 Post(s)
    Okay, I am planning on fiberglassing my headliner and have some questions. Also just to let you know this will be my first fiberglassing indevor.
    First it will be going in an 85 caprice. Now what im thinking is just take down the headliner, lay it down then tape it up so I can get the mold off. Then lay down some fleece and start laying on the resin. Now to the questions.
    1. What can I do to keep the strength of the mold since fiberglass is strongest in curves and this will have long stretches of flatness. Will it be strong enough like that?
    2. How do you make the mold come off without tape coming with it? Is there something to make it come off easier?
    3. Where can I get a good amount of fleece at? Fabric shop?
    Any help will be greatly appreciated. Thanks
    repo24's Avatar
    repo24 is offline ima n00b
    Dec 2004
    Watertown, SD
    171
    Re: Fiberglassing headliner...
    1. put on lots of layers of heavy chop mat
    2. put some type of lubricant on the tape before you start glassing, such as wd-40, pam, silicone spray, etc. EDIT: I have also heard that blue "painter's tape" lets the mold come off easier, but have not tried this myself.
    3. A fabric shop would be your best bet. Heck, if you find it on clearance, you can get 1yd x52" for like $3-4.
    Hint: Buy your resin/hardener/fiberglass mat at a marine supply store, it is MUCH cheaper...
    Team H20 town
    bigwheel15's Avatar
    Jan 2004
    Fort Worth,Texas
    25
    3,761
    21 Post(s)
    How many layers should I put? I can get the resin free so im not too worried about that.
    robbie_turner's Avatar
    robbie_turner is offline Senior VIP Member
    Oct 2004
    Birmingham, UK
    32
    221
    depends on how big your speakers are going 2b. im in the middle of doing the same thing. it depends on your mat i would think 3 or 4 will be ok.
    Dont buy Sony like i have!!!!
    cheeseburger35's Avatar
    cheeseburger35 is offline CarAudio.com Elite
    Dec 2004
    Okc, Ok
    1,320
    i didn't even think he was using speakers in his headliner....i took it as he just wanted it fiberglassed but maybe i'm wrong
    Jesse98's Avatar
    Jesse98 is offline Senior VIP Member
    Jun 2004
    Clyde, NC
    27
    189
    if you were willing to waste a headliner it might be tons easier just to resin the fabrick on the headliner and then fill over it. or not, if the headliner isnt holding any wieght other than itself 2-3 layers should be fine. gonna look cool, gonna post pics when its done?
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    27
    15,432
    21
    what are you glassing this thing for? just to paint? if so- go to a junk yard and pick up one outta an old junker, and just drop resin on the whole thing and let it dry (hopefully it will fit and not warp)
    you DO NOT want to use 'fleece' instead of fiberglass, UNLESS you are making a stretch mould. otherwise, a few layers of fiberglass should be fine
    crhye250r's Avatar
    crhye250r is offline Installer
    Oct 2002
    Clay, KY
    28
    985
    Just a thought. Once you get the glassed piece finished, how do you plan on getting it back into the car? I have recovered several headliners, and haven't been able to get a single one back in without bending it. The only way i could possibly see getting it back into the car is remove the windshield or back glass.
    MECP Certified Installer
  9. #9
    smullen's Avatar
    smullen is offline CarAudio.com Elite
    Aug 2003
    St. Louis
    39
    1,961
    29
    Quote Originally Posted by crhye250r
    Exactly what I was thinking, except I did not think the window trick would work as the headliners are usaully wider than the front or rear windshield....
    I have seen a few headliners done like this and they were all dine in the truck itself... Talk about a PITA..... Applying resin upside down, then all that sanding and then finally painting upsde down.....
    Sheesh,,,
    NRA Lifetime Patron Member
  10. #10
    bigwheel15's Avatar
    Jan 2004
    Fort Worth,Texas
    25
    3,761
    21 Post(s)
    Hhmmm, you do have a point. I have a wagon so I have a little room to get it out, I only need a slight bend to remove it. Is it really that strong that there is no bend in it, what if I just use 2 layers, would it be bendable yet still hold its shape well?
    IF this works I can just resin the headliner, because the main reason for this is to paint it. If I do this would it likely warp it, or is it just an off chance?
  11. #11
    BDIDDY's Avatar
    BDIDDY is offline Sittin' Slick
    Mar 2003
    Tennessee
    25
    2,575
    I would try to find a nice headliner with the material already on it, no sags or huge rips, then drop some resin onto it. Once you are done there come back with some kitty hair, just for extra comfort when bending it to get it back in the car. Have fun getting that thing prepped and straight for some paint...
    "Just have to remember to take everything in stride, and don't put off till tomorrow what you can do today because there might not be a tomorrow. " <---- RAMOS
    Profliepower is the funniest guy ever...
  12. #12
    bigwheel15's Avatar
    Jan 2004
    Fort Worth,Texas
    25
    3,761
    21 Post(s)
    That is actually a very good idea BDIDDY, looks like I have my plan, any objections?
  13. #13
    smullen's Avatar
    Aug 2003
    St. Louis
    39
    1,961
    29
    Quote Originally Posted by bigwheel15
    I dunno, I'm thinking if you flex it its gonna break..
    If you make it strong enough to not break, it won't flex enough to fit in the ride...
    Have you glassed anything before??? I'd deffinatly try one from a junk yard 1st just to get down your technique.... Gotta start somewhere...
  14. #14
    BDIDDY's Avatar
    Mar 2003
    Tennessee
    25
    2,575
    Quote Originally Posted by smullen
    I don't think it would crack all that easy with 2-3 layers plus a small layer of kitty hair. Plus he has a wagon so it's not gonna be that hard to get it in and out...
  15. #15
    bigwheel15's Avatar
    Jan 2004
    Fort Worth,Texas
    25
    3,761
    21 Post(s)
    Yeah smullen, im going to the junk yard christmas break and getting a headliner from another caprice wagon. Also yes, this is my first attempt to fiberglass so I think it will be a good practice and learning experience. Do you think ill need to use and body filler?
  1. Where to buy raw materials for fiberglassing
    By MetalMaxima in forum Enclosure Design & Construction Help
    Last Post: 12-04-2004, 02:59 PM
  2. Anybody have a DIY on fiberglassing
    By LooKin4Boom in forum Enclosure Design & Construction Help
    Last Post: 11-12-2004, 11:46 AM
  3. Fiberglassing & DavidFRE's box this week
    By BiaBia in forum General Discussion
    Last Post: 09-24-2004, 01:13 AM
  4. Finding fiberglassing supplies
    By Heresy in forum General Discussion
    Last Post: 07-14-2002, 01:31 AM
  5. fiberglassing
    By cadillac1892 in forum Wiring, Electrical and Installation Help
    Last Post: 02-05-2002, 12:49 PM
