Results 1 to 10 of 10
Reload Thread: Clearance of sub from base
    tractng's Avatar
    tractng is offline Member
    Sep 2004
    Los Angeles
    76
    Guys,
    Because of the height limitation of my location. I was able to build a fiberglass box (sealed) that had a mounting depth of 6.5 inches. The sub is 6.18, so I have about 1/4 inch from the magnet to the base.
    The magnet has a small hole on the bottom (for air I guess). Do you think I should have any problem with the clearance? My volume is .84 cubic ft which I meet the manufacturer's suggested internal.
    The sub I am going to use is a Diamond Audio Mark2 10".
    Thanks,
    Tony
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    Re: Clearance of sub from base
    It's normally a good idea to leave 1-2" clearance between a vented pole & a wall. This is one of the primary ways to cool the coils. Can you put a 1/2" spacer between the driver & enclosure?
    What the f00k happened to this place?
    tractng's Avatar
    Sep 2004
    Los Angeles
    76
    NjccBflo,
    I tried with an extra 1/2 inch ring, but could not get it to fit the opening (past the opening I have a lot room). I am putting on a 350z .
    Tony
    Nikuk's Avatar
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    Quote Originally Posted by tractng
    NjccBflo,
    Tony
    I expected as much... how much wattage are you running to the driver? Are you planning on using Dacron or Polyfil?
    Considering that You've already built the enclosure, I dont suppose you'd like to build another...
    The absolute best thing that I can advise is to e-mail Diamond Audio. They can advise you about what that Driver will need as a minimum.
    >Nick
    tractng's Avatar
    Sep 2004
    Los Angeles
    76
    Njcc,
    No Dacron or Polyfil? I will be driving it 600 watts (xenon 600.1). I spent over $100 and so much time on it too (over 50hours).
    Tony
    Nikuk's Avatar
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    Well, generally small sealed's love Fill. My concern arises around the need for the motor to breathe, as it were.
    That driver's rated for 800rms, yes?
    I dont know that motor structure at all, i dont know how well it'll cool itself without much excursion, or in that box with a shallow mounting.
    Contactn Diamond Audio.
    Strecker25's Avatar
    Strecker25 is offline Better than everyone
    Feb 2004
    Rochester, NY
    30
    989
    my m6s cooled just fine in a small sealed box with an inch clearance from the back wall for almost a month, i have the original and not the mk2 but i believe the motor is fairly similar. Give it a shot and just keep an eye on it, when your through playing it for some time on a decent volume give the dustcap and the surrounding cone a touch, it should be warm but not really hot. And of course dont touch the cone while its on (just had to throw that out there)
    Panasonic CQ-HR1003U
    Twin Diamond Audio M6 12D4's
    3.2Ft^3 @33hz
    Viper Audio d1200.1
    Diamond Audio M651 5.25" components
    Profile Clarus CL800
    200amp alt, big3
    2 Gallons of eDead v3 ( Group Buy )
    40sqft eDead V1se
    20sqft Dynamat extreme
    Pictures of the setup
    Video of the M6's
    All in a 94 Lumina
    tractng's Avatar
    Sep 2004
    Los Angeles
    76
    Strecker,
    When you say the cone, you mean the top of the sub right? Couldn't imagine me taking out the sub off the box and touching it on the magnet.
    Tony
  9. #9
    Nikuk's Avatar
    Jul 2004
    Buffalo, NY
    37
    7,854
    1 Post(s)
    Quote Originally Posted by Strecker25
    You're working with 1"... He's working with <1/4".
  10. #10
    swimfreak26's Avatar
    swimfreak26 is offline I am cool
    Aug 2002
    East Lansing, MI
    3,132
    Can you mount it inverted? Just an idea, not sure if it's possible in your situation.
    Fuc, how come when I copy and paste **** it never gives me the cool blue thing in my sig. Sonofa*****withhotredtabascosauceonmynutz!!!!!
    References: g30ffr3y,Cjjackson85,Pearldrummer, Rattlebrain, Harrison486, excelerater, ax600, XtrmAudioCncpts
  1. Power Base
    By kustyn727 in forum General Discussion
    Last Post: 11-14-2004, 08:14 PM
  2. Power Base
    Last Post: 10-31-2004, 10:42 PM
  3. power base subs!!!
    By Hurst421 in forum Subwoofers
    Last Post: 07-10-2002, 10:11 PM
