Mounting Diameter (top mount) : 275mm (10-7/8”) (from the subs manafacture site) Do I cut the hole that big or do I leave a half inch for mounting.
cut the hole at that then it should fit perfect
cut the hole that big.
if you are flush mounting you need a hole that big to the interior of the box and a hole the outer diameter on the exterior of it.
What the f00k happened to this place?
Originally Posted by NjccBflo
Got the first part, completey lost on the second....none of yall would guess I am MI would you...lol
He means...
Basically, this would be the first one.
"===" designates fiberboard.
.....│______________│ <-- your sub basket/grille goes on top.
=====│_________│====
by the SECOND one. If you want your grille or basket BENEATH the top of the wood, you need to make the wood double thick (usually)(with screws and woodglue or equivalent) And cut the SAME size hole, but using a router and jig or a HUGE holesaw (if you can find one)... Cut a LARGER hole above the first one.
===_______________===
===│_____________│=== This would be flush mounted.
=====│ ________│=====
Merry Christmas.
MI?
Just stick with a 10 7/8" hole
*thanks jon
MI= military intelligence
LoL... that requires the bigger parts of your brain... so dont feel bad!
Bookmarks
