Results 1 to 4 of 4
Reload Thread: Is it ok to do this?
    bushtree's Avatar
    bushtree is offline CarAudio.com Elite
    Sep 2003
    San Diego
    547
    Hey everyone i will be building a box for 2 12" woofers. Anyways they are going to share one chamber. But they will each have their own amplifier. Is this ok to do? I just have to link the amps tougher so they hit at the same time right?
    There will be a plexiglass window so i cant really put a wall in the middle to split it up into 2 seperate chambers.
    Thanks,
    reed8857's Avatar
    reed8857 is offline SRT 4 (neon with balls)
    Dec 2003
    Atlanta/Deployed Kuwait
    264
    Re: Is it ok to do this?
    This question might get answered better in one of the installation forums...up top FYI
    bushtree's Avatar
    Sep 2003
    San Diego
    547
    Oh ok ill post it there.
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,706
    97 Post(s)
    is the box ported or sealed? If it's ported, then common chamber is better for DIY projects: it takes less work to build and design one correct port than two identical ones. If it's sealed, then there's no real problem with a CC box, you just get more bracing with seperate chambers (and insurance in case one driver goes, it doesn't take the other one with it).
