Results 1 to 2 of 2
Reload Thread: ported box questions
    Jan 2004
    Detroit, MI
    44
    i know this has probably allready been covered but i checked with the search engine as well as i could and it didn't seem to directly adress this question or everybody allready knows the answer. How exactally do you calculate port displacement? like is it the entire space taken up by the port or just the wood. and When using the port dimensions calculator is the volume you use before or after port displacement. thanx for your time guyz
    rawmaterial's Avatar
    rawmaterial is offline Noobie
    Sep 2004
    Hawaii
    28
  1. sub selection
    By DeKaL44 in forum Subwoofers
    Last Post: 12-08-2005, 03:35 AM
  2. Ported Box for....
    By kbkid in forum Enclosure Design & Construction Help
    Last Post: 11-14-2004, 06:09 PM
  3. Slot Ported Box
    By Jonahdude in forum Enclosure Design & Construction Help
    Last Post: 11-07-2004, 05:06 PM
  4. box recomendations for my trunk? needs a rebuild, low ported space
    By maniackilla in forum Enclosure Design & Construction Help
    Last Post: 10-08-2004, 11:51 PM
  5. Post Your Ported Box Dimensions For Everyone!
    By req in forum Enclosure Design & Construction Help
    Last Post: 10-06-2004, 07:56 AM
