Results 1 to 13 of 13
Reload Thread: Bracing?
    bamaboy's Avatar
    bamaboy is offline War Eagle!!!
    Oct 2004
    Auburn, Alabama
    24
    7,205
    Icon30 Bracing?
    Do i need to brace my box.Its gonna be a 2.5 cu ft tuned to 35hz. its for 1 SX12.
    And does anyone know of home depot cuts wood for you?What items do i need to put it together?I have all the tools, but like glue,nails,so on. Do i need a double baffle?
    plazman's Avatar
    plazman is offline CarAudio.com Elite
    May 2004
    USA
    661
    Re: Bracing?
    i wouldnt let home depot cut it for you.
    cut it yourself. borrow a friends table saw.
    bracing wouldnt hurt.
    IgnoreMe's Avatar
    IgnoreMe is offline I love 2 girls 1 cup
    Dec 2003
    caraudio.com
    27
    11,768
    Re: Bracing?
    yea homedepot cuts them. they do a nice job when they get it right. so far though, they have always screwed up at least once. either they cut 1 peice 1/2" short, or they only cut 1 piece of a certain size when i needed 2. so im usually stuck cuttin the rest of the wood that i paid for at home. but yea they make pretty accurate cuts when you have an experienced guy cutting, keep in mind a lot of the younger less experienced ones can easiliy to be called to assist you. and depending on your port walls, if they are long enough, in a small box like that they will act as braces themselves.
    llllllllllllllll Educate yourself and help stop the ignorance.
    llllllllllllllll DEA Judge Francis L Young says...
    llllllllllllllll Designing a Ported Box
    refs: hazardous0388, snoopdan, karleon, thelow, freezeman_7, imtjnotu, Gebrochen, astroladespl, billabongcr , mustbenu , thunder9500 , 91ser, djdilliodon (6 times), stupify, milenko515, Zeuslicious, Bmoorman05, WaTTsLOk187, too dope 1904, nate2587, rbiele126, denalilvr
    Don't Blame Me. I Voted for Ron Paul.
    BluePoint Air Ratchet for sale...click me bitch
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    32
    4,234
    Re: Bracing?
    use screws...not nails.
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    ss3079's Avatar
    ss3079 is offline Eh Dere Hi Dere Ho-ser
    Mar 2002
    Up North
    22,571
    Re: Bracing?
    Quote Originally Posted by jellyfish420
    Nails could work. Screws just seem to be easier.
    I can build a box and use clamps to hold it together while it dries and it'll be just as strong as your box with screws.
    - Steve
    Moderator
    2007 Chrysler 300C
    2005 Chevrolet Silverado 2500HD Crew Cab
    Optima, Volant, Bully Dog, Corsa, Gibson, Powermaster, California Super Trucks, Fox Racing, Airaid
    Alpine 7998, Alpine HDA-5460, Arc Audio MEQ-30, (2) Adire Audio Shiva, Image Dynamics CD-2COMP, Image Dynamics CX64, (2) Image Dynamics ID8V.2, Arc Audio 2100CXL, Arc Audio 4150CXL, Arc Audio 1500D-R
    2006 Kawasaki Ninja ZX14
    Quote Originally Posted by DJGTSR
    I dont mean to be rude, but what is the highest level of education that you finished?
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    30
    873
    Re: Bracing?
    nails would only work if they are sawtooth nails and with glue like u used cuz i tried using nails on a single 12" box and as soon as it hit a few bass notes the box just blew apart.
    rippinitup7's Avatar
    rippinitup7 is offline CarAudio.com Elite
    Jun 2004
    ohio
    552
    Re: Bracing?
    do not use nails.
    -04' ram 1500 quad cab short bed.
    -98' grand cherokee laredo.
    dirtypool's Avatar
    dirtypool is offline Junior Member
    Nov 2004
    Fresno, CA
    21
    Re: Bracing?
    Glue and clamp will be strong. Screws are preferred though as they sort of "clamp" for you. In a properly glued and clamped joint, the wood will break before the glue joint will.
    I would go to a cabinet shop before I would let a mass merchandiser cut the wood. You can usually get a local cabinet shop to make your cuts for you and they will be dead on. Pretty cheap too, as it should be cheaper than the cost of one bad cut. They are generally more familiar with box building than most of your Home Depot/Lowes employees.
    my .02
  9. #9
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    Re: Bracing?
    Quote Originally Posted by dirtypool
    Exactly. Thank you very much.
    - Steve
    Moderator
    2007 Chrysler 300C
  10. #10
    kickerlivinloud's Avatar
    kickerlivinloud is offline Banning survivor
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Re: Bracing?
    Nails are fine if your carful. I used finish nails on mine and used a lot of them. Never had a problem, just lots of nails and lots of glue and your good. You shouldn't need bracing, my box is around 3.7 and shows no sign of needing any type of bracing so you should be good.
    Jon
  11. #11
    Jul 2004
    STL ill side
    32
    4,234
    Re: Bracing?
    Quote Originally Posted by ss3079
    - Steve
    i didn't doubt you...its just screws are easier to use than nails.
    my .02
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
  12. #12
    ss3079's Avatar
    Mar 2002
    Up North
    22,571
    Re: Bracing?
    You got that right ... unless you've got a compressor.
    - Steve
    Moderator
    2007 Chrysler 300C
  13. #13
    Feb 2004
    Finger Lakes, NY
    26
    3,280
    Re: Bracing?
    Compressers are nice thing to have Saved me a lot of work.
    Jon
  1. Bracing
    By LIGHTBEING in forum Enclosure Design & Construction Help
    Last Post: 11-15-2004, 03:25 PM
  2. bracing needed for ported box???
    By chinxtaboi in forum Subwoofers
    Last Post: 08-27-2002, 10:57 PM
  3. box bracing?
    By more_spl in forum Subwoofers
    Last Post: 07-10-2002, 03:32 PM
  4. Box Bracing
    By Registered in forum General Discussion
    Last Post: 06-13-2002, 08:08 PM
