Results 1 to 2 of 2
Reload Thread: Bracing
    LIGHTBEING's Avatar
    LIGHTBEING is offline CarAudio.com Elite
    Jun 2004
    New Jersey
    866
    Bracing
    Hey guys.
    Well I built my box yesterday. Came out pretty **** good. I left the top off so I could caulk it real good tonight. and I was thinking about adding bracing. Below is the box I built however, I don't think it took in account the bracing.
    http://community.webshots.com/photo...118877865yGoHue
    so if I add this bracing it will take away some volume. Right now it's 4 cuft after port and sub displacement. So how much will the bracing take away? And what is the best way to brace it? I guess what I'm asking is what is the smallest brace I can use? I don't want to sacrifice that much space. Also, will screws hold the sub in place? Or should I get some type of brackets. I remember reading something about tnuts? Also, remember reading about bracing on the inside for the sub magnet to sit on. Any suggestion for that? or will screws do the job?
    HU: Kenwood Excelon DDX-7015
    Sub Amp: US amps MD2D
    Sub: 12" RE XXX
    Comp Amp: SS Reference 700s
    Comps: CDT HD-62
    Rearfill: CDT CL-6X
    Box: 2.5 cuft after displacement
    Kinetik HC1800
    OG 185a HO Alt
    100 sq ft eDead
    Custom Trunk
    IgnoreMe's Avatar
    IgnoreMe is offline I love 2 girls 1 cup
    Dec 2003
    caraudio.com
    32
    11,768
    1 Post(s)
    Re: Bracing
    as far as bracing goes, just use 1.5" diameter dowls for the bracing and it will minimize the ammount of volume you will loose. just 2 up and 2 across or 1 up and 1 across. my friend doesnt have any bracing besides the port that runs across the box and it does fine since the box is pretty much a cube. if your box is more rectangular and you have a real long side though i would suggest bracing since the longer a side is the more prone it is to flexing. your pic dont work so you will have to make that assumption. and for the screws, my friend 15" xxx is being held up fine with just 8 screws right through. you can if you want make make a mdf ring and put it on the inside and have the screws come from the outside through the holes for the sub and then into the mdf ring that you placed on the inside.
    llllllllllllllll Educate yourself and help stop the ignorance.
    llllllllllllllll DEA Judge Francis L Young says...
    llllllllllllllll Designing a Ported Box
    refs: hazardous0388, snoopdan, karleon, thelow, freezeman_7, imtjnotu, Gebrochen, astroladespl, billabongcr , mustbenu , thunder9500 , 91ser, djdilliodon (6 times), stupify, milenko515, Zeuslicious, Bmoorman05, WaTTsLOk187, too dope 1904, nate2587, rbiele126, denalilvr
    Don't Blame Me. I Voted for Ron Paul.
    BluePoint Air Ratchet for sale...click me bitch
  1. Ported Box for e12k
    By jack in forum Enclosure Design & Construction Help
    Last Post: 11-04-2002, 10:55 PM
  2. bracing needed for ported box???
    By chinxtaboi in forum Subwoofers
    Last Post: 08-27-2002, 11:57 PM
  3. box bracing?
    By more_spl in forum Subwoofers
    Last Post: 07-10-2002, 04:32 PM
  4. Box Bracing
    By Registered in forum General Discussion
    Last Post: 06-13-2002, 09:08 PM
  5. need advice for putting vblock in my box
    By crzybob77 in forum Wiring, Electrical and Installation Help
    Last Post: 05-01-2002, 07:39 PM
