Results 1 to 5 of 5
Reload Thread: Where to point ports
    Scarenius's Avatar
    Scarenius is offline Call me Ravo
    Jul 2004
    Michigan
    479
    Does it matter what direction the ports are pointed in relation to a sub? If the sub is facing the rear/front/left/right and the port ISN'T facing the same direction, how will it affect performance?
    Current Setup
    "Power is probably the least efficient way of increasing SPL."
    - Jmac
    78nova's Avatar
    78nova is offline XXX
    Jan 2004
    Bovina, Texas
    32
    868
    Re: Where to point ports
    i guess if your in a hatchback i would go up, but in a trunk point it away from the cabin, thats my opinion
    Quote Originally Posted by sbcaprice305
    lets see..........
    2 guys + alot of booze +hotel room + 0 females = 2 soar @ssholes
    My Current Setup
    subwoofers: 2 12" xxx's dual 4ohm
    sub amp: orion 2500d soon to be RF t30001bd
    head unit: alpine 9833
    speakers: stock
    wiring: stinger 0/1 gauge amp kit
    enclosure: 4.5 cubic ft. tuned to 34hz
    all wrapped in a 99 town car with 22's O yeah.
    BASS OUTLAW's Avatar
    BASS OUTLAW is offline Single sub fan
    Apr 2004
    next street
    32
    1,120
    am not sure actually,
    SPL guys test the port in many direction untill they get the maximum db.
    if u r not entering a comp, i dont think it would make that big difference.
    if it was me, and in a trunk, would make the port facin UP-wards, or same side as the sub.
    wait for other comments though.
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    35
    873
    ive tried ports in just about every direction and they all sound about the same to me exept for the times that the port was blocked by something in the vehichle. So just put the port in an area that allows air flow. Technically speaking you can improve the volume by facing the port in certain directions depending on the vehicle and position of the box but usually it is only a few tenths of a dB.
    Scarenius's Avatar
    Jul 2004
    Michigan
    479
    A few tenth of a decibel is irrelevant. You see, I basically want to just drill a hole and add a piece of PVC pipe to port the sh*tty box my 15s are in. It's 1/2" chipboard, a "mastercraft" or some BS company like that, 2.15 cubes per 15. Port size, maybe a 3 inch diameter. I did the math, it's like 4.5 inches long, 11 and some odd inches if I use two 3 inch dia ports. I'm not aiming for perfect, if I'm off by less than 5 hertz, I don't think I'll notice the difference.
    The subs aim towards the rear of the car. I will point the ports straight up. There's about 5 inches clearance and a bass port, but 2 chunks of sound insulation in the way. Should be fine.
    Current Setup
    - Jmac
  1. multiple ports
    By paikiah in forum Enclosure Design & Construction Help
    Last Post: 01-03-2003, 05:50 PM
  2. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  3. 2 Ports?
    By Slaymon in forum Enclosure Design & Construction Help
    Last Post: 12-24-2002, 04:21 PM
  4. Need help with box and ports
    By Sspider in forum Wiring, Electrical and Installation Help
    Last Post: 03-11-2002, 03:09 PM
  5. how far from the bottom of the box should my ports be?
    By Unregistered in forum Wiring, Electrical and Installation Help
    Last Post: 01-25-2002, 09:00 PM
