Results 1 to 6 of 6
Reload Thread: two 10" SE's
    vinnie_febs's Avatar
    vinnie_febs is offline Member
    Mar 2004
    md
    43
    two 10" SE's
    Hey guys I need your help. I just built my first box (yeaah) but it looks tiny as hell. I know that they are supposed to have like .65 cuft each. So I went to a website (12volt) and got some perimeters from it, and this is what it came out with: 27" wide, 14" height, and 9" in depth. Doesn't this seem kind of small?
    Exaran's Avatar
    Exaran is offline Sound Scrounger
    Oct 2004
    Richmond, VA
    90
    Re: two 10" SE's
    if thats internal dimentions, its a lil big...
    if external, and you're using 3/4" MDF, thats about right...
    You may want to add a partition in the middle (to seperate the subs) and make the box 3/4" wider to compensate. MAke sure 9" will be deep enough for those subs too and some air behind them for cooling
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    Re: two 10" SE's
    thats .69 cubic feet per sub before the subwoofers displacement. The sub takes up ~.15 if i remember right, so you need one a little bit larger. 1.6 cubic feet before both subs go in would be perfect.
    Mar 2004
    md
    43
    Re: two 10" SE's
    Quote Originally Posted by Moe Lester
    That's what I was afraid of. I thought maybe the .14-15cuft was already taken in consideration when the manufactures asks for .65cuft per sub. Do you think some poly would help? Or is it too late? 'cause I'm almost done with the set up.
    Moe Lester's Avatar
    Dec 2003
    Houston, TX
    31
    3,614
    Re: two 10" SE's
    Just stuff it w/ polyfill and it should be fine.
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    32
    15,426
    21
    Re: two 10" SE's
    make it big. make it ported.
    then the should wang on ~300w
    yum. wangage. (hahaa)
  1. 2 RE 12" SE's
    By djXternal in forum Amplifiers
    Last Post: 09-29-2004, 03:32 PM
  2. 10" MTX T6104A vs. 10" re RE ?
    By Tater_Salad in forum Subwoofers
    Last Post: 09-27-2004, 07:04 PM
  3. RE SE's...
    By violator5spd in forum Subwoofers
    Last Post: 11-16-2002, 12:16 AM
  4. One Brahma 10" or two 10" W3's...
    By beachboy016 in forum Subwoofers
    Last Post: 10-01-2002, 05:17 PM
