Results 1 to 2 of 2
Reload Thread: is this box work pls check IT
    timythea05's Avatar
    timythea05 is offline Member
    Oct 2004
    ca
    47
    will be this okay enough this will be controlled by a rockford 500watts this is d only space available in the trunk
    Attached Thumbnails Attached Thumbnails is this box work pls check IT-boxx.jpg
    BulldogSr04's Avatar
    BulldogSr04 is offline CarAudio.com Elite
    Aug 2002
    Jennings, LA or Baton Rouge, LA
    32
    874
    Re: is this box work pls check IT
    Port is kind of small. Is that prefab? L5's or L7's? Or knock-off's?
    I wouldn't recommend that. What kind of trunk do you have? If you have 2 L5s, try to keep the port area at least 50 sq inches. L7s, I would do 100.
  1. Box Volume.
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 02-24-2003, 02:37 AM
  2. Ported Truck Box 2 alpine 10's
    By Jearod in forum Enclosure Design & Construction Help
    Last Post: 12-01-2002, 09:53 PM
  3. jl sub box
    By slick rick in forum Subwoofers
    Last Post: 06-23-2002, 08:49 PM
  4. BOX?? Whats Box, I have no BOX
    By nicster in forum Wiring, Electrical and Installation Help
    Last Post: 04-01-2002, 02:55 PM
