Results 1 to 5 of 5
Reload Thread: Re8 box plans
    sampson's Avatar
    sampson is offline CarAudio.com Elite
    Dec 2003
    Northwest area
    32
    1,246
    1 Post(s)
    Re8 box plans
    Ok heres the deal,
    I am throwing 4 re8s in 2 boxes one behind each seat in my truck. Each box is going to give them .92 cub feet of air. So like .46 a piece for anyone who doesn't like math. I have heard for a local guy that I shouldn't put a wire receptor deal on the box that you put the positive and negative wire into but rather just run it straight off the subs and out a little hole in the side of the box, then just use like great stuff to seal the hole to make the box tighter.... What do you guys think about this? He also said that I should leave the box sealed. I am pretty sure he is wrong on that part as RE specs say .5 is rec. port size and as I am really close I figure I should port it...but still give me opinoins on it. I'd also like opinions and recomendations on weither or not to use weather stiping along the sub mounting area and what I should tune the boxes to? Any other advice or suggestions are welcome.
    So give me your opinion on
    1. port or sealed?
    2. run wire through hole in box or not?
    3. what to tune the box to?
    4. yes/no on weather striping
    5. ANY OTHER ADVICE OR SUGGESTIONS AT ALL.
    Thanks a lot in advance-Sampson
    PS. boxes are made out of 3/4 mdf incase anyone was wondering
    Exaran's Avatar
    Exaran is offline Sound Scrounger
    Oct 2004
    Richmond, VA
    90
    Re: Re8 box plans
    Dont forget, if you port, you have to add the port volume and speaker volume to that .5 so it starts to turn into .6 or .7 each. You may have to stay sealed if you can't do that much volume
    If you find some good terminal cups you'll have a good seal, or else that guys idea will work. Only problem is that you loose the ability to dissconnect the box easily if you ever want to use that space.
    RE says to port to 32hz for SQL... I'm getting ready to port my RE8 to 28hz for pure SQ (it makes the curve a lot flatter and lower in WinISD @ .6 cubes at 28hz)
    You need some kind of gasket under the speaker... I ran my RE8 without one for a little while, and it made some crazy whistling noises
    good luck
    sampson's Avatar
    Dec 2003
    Northwest area
    32
    1,246
    1 Post(s)
    Re: Re8 box plans
    Thanks for the advice. I really appreciate it. Anybody else have anything to add? I think I need to talk to a box builder as I am now reconsidering porting the boxes. Thanks for the post-Sampson
    BiaBia's Avatar
    BiaBia is offline Senior VIP Member
    Jun 2003
    Hampton, VA
    1,438
    9 Post(s)
    Re: Re8 box plans
    Get me on AIM, I have plans for a ported box.
    -Alex
    AIM - Biabia322
    E-mail - [email protected]
    1993 300zx Slicktop - Undergoing TT transplant
    HU - Pioneer Premier 740mp
    Front Stage - Rainbow SLC 265
    Front Stage Amp - US Amps 800.2
    Subwoofers - (2) 10'' Sundown SD-1's
    Subwoofers Amp - Sundown 100.4
    "When my GF's 9-year-old niece told me that she would "pop" me in the mouth if I told her to be quiet again, I retorted, "Pop me in the mouth and I'll pop your cherry." -Jmac
    Mr. Loki's Avatar
    Mr. Loki is offline Banned
    Sep 2002
    Missouri
    34
    5,856
    Re: Re8 box plans
    What would help alot is the max dimensions you can use in your truck behind the seat then we can calculate what kinda air space you have to work with and go from there. I say the little drilled hole idea is fine as thats how i do mine. Then you dont have to worrt about the terminal messing up or the wire rattling off and so fourth...normal water proof acrilic caulk works fine. Re subs seem to sound GREAT in ported boxs, but if you can do that you can go sealed, but I would have to say 2 re8s ported will sound better then 4 re8s sealed depending the power and so fourth.
  1. Box Volume.
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 02-24-2003, 01:37 AM
  2. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  3. ATTN: Jmac!
    By MUGEN! in forum General Discussion
    Last Post: 12-31-2002, 04:42 AM
  4. plans for my custom box...does this sound right???
    By justchillin in forum Subwoofers
    Last Post: 03-31-2002, 11:25 PM
  5. Replies: 2
    Last Post: 03-09-2002, 12:57 PM
