Results 1 to 10 of 10
Reload Thread: standard box adding fiberglass?
    vosschs's Avatar
    vosschs is offline Banned
    Oct 2004
    just east of STL
    26
    5,658
    i have a standard mdf carpeted box for 2 twelves im thinking about tearing off the carpet then making it fiberglass over top of the mdf would that work? sound good etc, because i want to do that put like 2-3 layers then put body filler on it then paint abd primer it pearl white like my t bird give me some feedback do's and donts?
    RattlinStratus's Avatar
    RattlinStratus is offline You Dumb Bastard...
    Jun 2004
    Hurricane Central
    27
    495
    Re: standard box adding fiberglass?
    Yes you can do that, I have seen someones regular sealed box fiberglassed so it was flush in the corner of his car, and it looked like it belonged there! The white paint should be sick, very original too.
    Current setup...
    Infinity 6.5s
    Infinity 6x9s
    Alpine Car Alarm for $14.00 installed (Workin at CC)
    Future Mods:
    Alpine 9825
    Some Amps
    More subs than my car can handle (Four)
    Hydraulics on a Stratus? Sure why not...
    vosschs's Avatar
    Oct 2004
    just east of STL
    26
    5,658
    ya i think i may do it, ill only need 2-3 layers if that, and does it matter what kind of "fleece" i use? any kind of fabric would work?
    xchaosx's Avatar
    xchaosx is offline CarAudio.com Elite
    Feb 2004
    pa
    579
    all your doing is refinishing the box you shouldn't need fleece you just wanna smooth it out right if that's the case just paint on some resine and bondo it and sand till smooth then paint it
    swimfreak26's Avatar
    swimfreak26 is offline I am cool
    Aug 2002
    East Lansing, MI
    3,132
    A period, a comma, a transitional phrase? Anything would have been very nice there so that someone could understand that statement.
    I think what he was trying to say though, is that if you are just going to use the glass as a means of making it look better (not changing it's shape at all), then you need not use any actual fiberglass at all. You could get away with just laying down a few layers of resin, and smooth that out wil bondo or body filler. Then just sand and paint.
    Fuc, how come when I copy and paste **** it never gives me the cool blue thing in my sig. Sonofa*****withhotredtabascosauceonmynutz!!!!!
    References: g30ffr3y,Cjjackson85,Pearldrummer, Rattlebrain, Harrison486, excelerater, ax600, XtrmAudioCncpts
    KARLEON's Avatar
    KARLEON is offline Livin' Legend
    Mar 2002
    Chattanooga, TN
    27
    1,993
    13
    Quote Originally Posted by swimfreak26
    Look at his avator, does it look like he would use a period, comma, transitional phrase? Just joking, but its cool. I understood him.
    ULTIMATE SOUNDS & PERFORMANCE Presents TWO DUDES SPL SHOOTOUT - 1st Place Champion
    REFERENCES: Bigbassman, Rangerman, Deserheat, Bavarian, Req, Vosschs, George, Mountaineer Man, NGSM13, Kingpin_jeffie, Harrison, Dustin19, Iceteebone, Electrodynamic, Memphis4L, RaiN, Mikemareen, Omietrice, Suleman36, Jmanpc, Kickerlivinloud, ibanender, massiveaudiocw, phoenix88, polecat, j3bus2k3
    req's Avatar
    req
    req is offline am a mod.
    Jul 2004
    Syracuse, NY
    27
    15,432
    21
    good idea, however badly it was written.
    just mix that resin to the specs on the can, paint it on, put some body filler down, make sure its all smoothe and hard, then paint.
    dont buy fiberglass unless you are going to mold it into the corner or physically change the shape of the box.
    vosschs's Avatar
    Oct 2004
    just east of STL
    26
    5,658
    so if i did this what should i do i have the box, i bought the fiberglass resin/catylyst, then do i even need cloth to put around the box? or just straight paint the resin on the box then put 2 or 3 coats on, then sand then il get my brother to put primer filler and paint it pearl white, would that be right for the fiberglass part i would need that inorder for it to be able to be painted ?
  9. #9
    kwang125's Avatar
    kwang125 is offline Senior VIP Member
    Jul 2004
    Canada
    154
    you don't need fiberglass cloth/mat !
  10. #10
    bigred78797's Avatar
    bigred78797 is offline Audiobahn Junkie
    Oct 2002
    Fort Meade, MD
    30
    873
    just spread a few coats of fiberglass resin, sand it down, bondo it, prime it, and paint it... there are a few extra sand it steps in between because you want it to be smoother than a baby's bottom. that is all i have done while putting a glassed type fininsh on a box. but you don't need any mat... just the resin.
  1. Box Volume.
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 02-24-2003, 01:37 AM
  2. detailed fiberglass box construction ??
    By Savant in forum Enclosure Design & Construction Help
    Last Post: 01-05-2003, 03:48 PM
  3. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  4. ATTN: Jmac!
    By MUGEN! in forum General Discussion
    Last Post: 12-31-2002, 04:42 AM
  5. new fiberglass box question
    By badboyzx2 in forum Enclosure Design & Construction Help
    Last Post: 12-30-2002, 02:44 PM
