Results 1 to 11 of 11
Reload Thread: 4" Port... Big Enough For This Box?
    Jonahdude's Avatar
    Jonahdude is offline ?????
    Feb 2004
    Florissant, MO
    29
    717
    If I had a box for 6 8" subwoofers, with a net volume of 4.46 ft^3, would a 4" port be big enough? It would be 3.5" long, which would tune it between 34hz and 35hz.
    New setup in the works:
    Vehicle: 1999 Ford Windstar
    Head Unit: Pioneer Premier DEH-P860MP
    Signal Processing: Profile Q100 3-Way active crossover, set to 80hz and 3.5khz
    High Pass: the legendary Aura tweeters powered by a Pioneer GM-3000T
    Band Pass: Ascendant Audio 6.5" Poly Midwoofers powered by a Pioneer GM-5000T
    Low Pass: Elemental Designs 19Ov.2 in 3ft^3 tuned to 30hz, powered by a Power Acoustik 2APC-1400
    Moe Lester's Avatar
    Moe Lester is offline 1/3 of TEAM PWNAGE
    Dec 2003
    Houston, TX
    31
    3,614
    Re: 4" Port... Big Enough For This Box?
    I would do at least 1 4" port per pair of 8s personally...
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    29
    717
    so 3 4" ports, how long would each have to be to tune to 35hz? Would it still be 3.5 inches, or does it change when you add more ports?
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    29
    717
    Bumped TTT!
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    29
    717
    TTT again...
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    29
    717
    Ttt, when adding more ports to you have to increase the length of each to maintain the same tuning?
    Exaran's Avatar
    Exaran is offline Sound Scrounger
    Oct 2004
    Richmond, VA
    90
    I just learned this last night:
    For multiple ports, just divide the volume of the enclosure of the box by the number of ports, and calculate each port by itself
    So with your numbers above, you divide 4.46 ft^3 by the 3 ports = 1.48 ft^3 per port
    Now calculate the port as you normally would to tune a 1.48 ft^3 box to 34hz... then make all 3 ports that size. Get it? If not, I'm just wakin up, I can clarify later...
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    29
    717
    Quote Originally Posted by Exaran
    Ahh, I get it, that makes sense. Can anyone verify that?
  9. #9
    Exaran's Avatar
    Oct 2004
    Richmond, VA
    90
    I got it off JL's tutorial site if you wanna check that out
  10. #10
    Jonahdude's Avatar
    Feb 2004
    Florissant, MO
    29
    717
    Alright, it's not that I didn't believe you it's just that you said you learned it last night.
  11. #11
    OLD_SCHOOL's Avatar
    OLD_SCHOOL is offline CarAudio.com Elite
    Aug 2004
    Buford, Ga. Metro ATL
    711
    hope your not tuning low
    dodge dakota 2003 quad cab
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    6.5 boston comps in the door ( maybe focal soon or ID)
    2 adire tempest 8 ft^3 @23hz
    1 hifonics bxD 1500
    1/0 power and stinger blocks terminals
    AIM Id traumanurse06 add me
    http://www.sounddomain.com/memberpage/681937/1 just set ti up so it is kinda lame
  1. SX box size and port...help
    By xtent in forum Subwoofers
    Last Post: 09-24-2004, 12:39 AM
  2. how big to make the ported box? need help fast..
    By geonn in forum General Discussion
    Last Post: 09-15-2002, 08:07 PM
  3. Built ported box, but have problems/questions...
    By F150Matt in forum Subwoofers
    Last Post: 08-11-2002, 09:28 PM
  4. How BIG is your Box???
    By dbhittin in forum Subwoofers
    Last Post: 04-24-2002, 02:51 PM
