Results 1 to 9 of 9
Reload Thread: questions for Jmac and the experts for xxx 12 box
    spr_f150's Avatar
    spr_f150 is offline Member
    Feb 2004
    South Louisiana
    83
    Icon32 questions for Jmac and the experts for xxx 12 box
    Help needed from the experts.
    12" xxx down firing
    02 f150 extended cab.
    I will use the 40 portion of the rear 60/40 split bench seat.
    Looking towards the back of the truck, using 3/4" mdf
    external box dimensions are...
    18" wide
    17" deep
    I can go as high as necessary to accomodate multiple boards for port.
    The bottom will be braced squared with 2x2's (1-1/2 x 1-1/2 actual)
    I'm looking to end up with between 2.5 - 3 cubes
    tuned to about 29 to 30. (unless the experts here advise different).
    Can anyone run these numbers and give me final dimensions??
    Chance89's Avatar
    Chance89 is offline CrAsHiNg *****
    Dec 2003
    Alberta
    30
    95
    Re: questions for Jmac and the experts for xxx 12 box
    20 inches high and your diminsions would give you 2.738ft3...I'd punch it in to see if it would work but I can't find xxx specifications on winisd. sry
    2000 chevy extcab
    Deh P660 HU
    Ag series 200 amp
    alpine type E 12(1.8ft sealed fibreglass under seat)
    kenwood tweets(lil pioneer 50w runnin dose)[/FONT]
    spr_f150's Avatar
    Feb 2004
    South Louisiana
    83
    I read in a thread here that driver displacement is .19 cu and the following is from re's web site.
    XXX12
    Fs 27.0 Hz
    Re 1.9 DVC
    Qms 4.52
    Qes 0.44
    Qts 0.4
    Sd om2 480
    Vas 56.5
    Xmax 32mm
    BL 17.1
    SPL 1W/1m 85.9
    RMS 1600 W
    Max 2500 W
    I notice that your calculation does not include driver, bracing, and port displacement.
    jellyfish420's Avatar
    jellyfish420 is offline i design boxes .......
    Jul 2004
    STL ill side
    37
    4,234
    i got 18x17x27 with a slot port that is 15.5x2 and 37"long tuned @30Hz
    psthe box dimentions are external.
    NEED A BOX DESIGN? PM ME
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    VIFA XT25 ring radiator 1"
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    spr_f150's Avatar
    Feb 2004
    South Louisiana
    83
    TTT (10 chars)
    spr_f150's Avatar
    Feb 2004
    South Louisiana
    83
    tttttttttt
    Jul 2004
    STL ill side
    37
    4,234
    what was wrong with the dimentions i gave you?
    HEAD UNIT
    860mp
    ACTIVE FRONT STAGE
    JBL GTO75.4 II
    RE 6.5
    SUB STAGE
    ega 1400d
    3HP FI
    STOLEN
    spr_f150's Avatar
    Feb 2004
    South Louisiana
    83
    Nothing "wrong" with what you gave, just wondering if anyone else has ideas/suggestions. Thanks for the info you have supplied.
  9. #9
    spr_f150's Avatar
    Feb 2004
    South Louisiana
    83
    Re: questions for the experts for xxx 12 box
    Quote Originally Posted by jellyfish420
    Thanks jellyfish. I've kinda changed my mind though. Instead of down firing, I think I'll go up firing. Pretty much same dimensions, but do you think I could fire it up with the port on the same face as the sub, but use a 3 inch port and tuned to about 33-35? How long should the port be and should I go larger than 27?
    Thanks for any help
