Results 1 to 15 of 15
Reload Thread: Orion HCCA Box plans....Can someone check it out?
    eFertLIS's Avatar
    eFertLIS is offline Member
    Apr 2004
    Philly, PA
    103
    Okay...after lots of reading, searching and calculating I came up with this....
    for a 2000 Orion HCCA 12D
    2.5 cu/ft tuned to 30 HZ
    14.5X2.5X35.49 (after port correction) internal port measurements
    The box will be made of 3/4" MDF
    outer dimensions
    Height 16
    Width 25.96672
    Depth 19.25
    I am mounting the sub on the long panel and having my slot on this plane running vertical using the side and back enclosure wall as part of the slot.
    The port displacement is 871.8125 going back and then 90 degrees to the right is 765.31.
    Bracing I will use 96cu/in total (8 4"sqaures cut into triangles and used in corners) and the sub displaces 244 cu/in.
    A total 1977.1225 cu/in = 1.144168 cu/ft of displacement.
    Did I screw this up or am I right? Thanks in advance.
    OLD_SCHOOL's Avatar
    OLD_SCHOOL is offline CarAudio.com Elite
    Aug 2004
    Buford, Ga. Metro ATL
    711
    Re: Orion HCCA Box plans....Can someone check it out?
    (36.25 * 1.84 x 10^8)/ (2.5 * 1728 * (30/.159)^2 ) - (.823 * sqrt 36.25 (port area )
    =38.41532
    port correction
    38.41532 - 1.25 = 37.16
    PLV= 37.16
    thats what i get doing it by hand and using your port area of 14.5*2.5 and your box volume of 2.5 ft^3
    means you port displacements are off also didn't look at your displacements but it is down the middle of the port
    hope this helps
    dodge dakota 2003 quad cab
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    6.5 boston comps in the door ( maybe focal soon or ID)
    2 adire tempest 8 ft^3 @23hz
    1 hifonics bxD 1500
    1/0 power and stinger blocks terminals
    AIM Id traumanurse06 add me
    http://www.sounddomain.com/memberpage/681937/1 just set ti up so it is kinda lame
    eFertLIS's Avatar
    Apr 2004
    Philly, PA
    103
    Using winISD Pro I got 36.74 as the length. I subtracted 1.25 from that. Is this software unreliable for calculating Port Length?????
    I then tried http://www.carstereo.com/help/Articles.cfm?id=31 which game me 37.2 which is very close to your number with correction. Math looks good on your equation....now I need to readjust my width and will post when I have new numbers. Thanks.
    Quote Originally Posted by OLD_SCHOOL
    =38.41532
    port correction
    PLV= 37.16
    hope this helps
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    yeah i always get diff numbers from winisd it it not real good for doing port length i just always do it by hand as most others do.
    do you have the pro update its gets a little closer to the numbers done by hand
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
    eFertLIS's Avatar
    Apr 2004
    Philly, PA
    103
    I have the latest version on the linearteam website. I tried to update it through the software but says its the latest version. So only if it was available elsewhere then I have the most recent.
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    ps remember when figureing your dispaclement it is down the center of the port
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    Quote Originally Posted by eFertLIS
    you have version o.5a87?
    if not here is the update link
    http://linearteam.proboards12.com/in...num=1063193736
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
    eFertLIS's Avatar
    Apr 2004
    Philly, PA
    103
    Can you elaborate on that? I remember a thread with a picture.....the first part goes back down a 16" piece.....I measured 3.25X18.5X14.5(inner height) for the first part and the new second part is 3.25X18.66X14.5
  9. #9
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
  10. #10
    eFertLIS's Avatar
    Apr 2004
    Philly, PA
    103
    Thanks for the link! Didn't have that version.
    New version gives me 41.71 inches though!
  11. #11
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    heheh yeah its ghey just go by the hand numbers hehh
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
  12. #12
    eFertLIS's Avatar
    Apr 2004
    Philly, PA
    103
    First link doesn't work....thanks for these by the way.
    Second link was the picture I was talking about. So....from that picture...port length starts at the opening in the middle and makes a left but your displacement doesn't start until the inisde of where the MDF would be if it went straight across the front baffle?????
  13. #13
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
  14. #14
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    same + .75 if it does not but against the baffle but sits on the outside just it behind the baffle and butted right against it this way you get .75 inches more room to mount the subs
    Mat
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
  15. #15
    OLD_SCHOOL's Avatar
    Aug 2004
    711
    you have a PM
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    1 hifonics bxD 1500
  1. Replies: 2
    Last Post: 09-04-2004, 03:34 PM
  2. Orion Hcca 425
    By F150Matt in forum Amplifiers
    Last Post: 09-25-2002, 06:33 PM
