Results 1 to 9 of 9
Reload Thread: Box Sealing?????
    ochem2012's Avatar
    ochem2012 is offline Junior Member
    Aug 2004
    Minneapolis, MN
    Box Sealing?????
    Question, I am building a custom box for my kappa perfect out of 1 inch MDF. I am going to seal the seams with silicon caulk, but what do I seal the seam around the sub with where it drills to the box????
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    36
    2,811
    Re: Box Sealing?????
    shouldn't be a problem, but if it does become one, you can use window weatherstripping.
    Einzee's Avatar
    Einzee is offline Service Professional
    Aug 2004
    Norwalk, CA
    44
    344
    4 Post(s)
    there is this product that is basically putty. comes rolled up like string its called "rope putty" or "rope seal"
    Stupid questions make more sense than stupid mistakes!
    It is best to remain silent and be thought of as stupid, rather than opening your mouth and removing all possible doubt!
    Quote Originally Posted by Twistid View Post
    Try taking the positive wire from your battery and run it to the engine block, see if that should fix things...
    Quote Originally Posted by PaulD View Post
    THE FUSE AT OR NEAR THE AMP PROTECTS THE AMP. WIRES DO NOT NEED "PROTECTING" WITH A FUSE SINCE THEY ARE NOT POWER PRODUCING DEVICES.
    Quote Originally Posted by shake this View Post
    Which one sounds better (short small diameter or long large diameter)?
    supa_c's Avatar
    supa_c is offline Abministrator
    Apr 2004
    In a chair
    19,369
    Kappa with 1" MDF, way way overkill.
    weather stripping is really cheap.
    xchaosx's Avatar
    xchaosx is offline CarAudio.com Elite
    Feb 2004
    pa
    579
    Quote Originally Posted by supa_c
    i'd say over kill
    ochem2012's Avatar
    Aug 2004
    Minneapolis, MN
    All I have guys is 1/2 inch MDF, so im going to glaze two layers and feather joint the corners. Why should I go buy more wood when I have lots of 1/2 inch lying around?? And I'd say 1/2 inch isnt enough. So weather stripping for sealing the sub to box eh?
    OLD_SCHOOL's Avatar
    OLD_SCHOOL is offline CarAudio.com Elite
    Aug 2004
    Buford, Ga. Metro ATL
    711
    your fine man i would do the saem thing in your situation if all i had was boat load of 1/2 laying around i would double wall it as well.
    as for sealing the sub you can put down weatherstriping but you usualy don't need to try it without first ad you will proably not need to do anything.
    PS over kill is ALWAYS better than underkill
    dodge dakota 2003 quad cab
    CLARION DXZ545MP
    Alpine MRV-T420 V12
    6.5 boston comps in the door ( maybe focal soon or ID)
    2 adire tempest 8 ft^3 @23hz
    1 hifonics bxD 1500
    1/0 power and stinger blocks terminals
    AIM Id traumanurse06 add me
    http://www.sounddomain.com/memberpage/681937/1 just set ti up so it is kinda lame
    ochem2012's Avatar
    Aug 2004
    Minneapolis, MN
    thanks OldSchool
  9. #9
    Fran82's Avatar
    Fran82 is offline Junior Member
    Sep 2004
    Lexington, SC
    17
    Overkill is usually the best with audio. If you don't want to bother with glueing up all the double panels, you could probably get away with just making some cross braces for inside the box. That should keep the box from flexing.
  1. Box Volume.
    By BigBoomer in forum Enclosure Design & Construction Help
    Last Post: 02-24-2003, 01:37 AM
  2. Sealing a box??
    By Kinalyx in forum Enclosure Design & Construction Help
    Last Post: 01-19-2003, 07:39 PM
  3. Box for 12 inch 8000 MTX
    By Clarion_Guy in forum Enclosure Design & Construction Help
    Last Post: 01-01-2003, 03:54 AM
  4. ATTN: Jmac!
    By MUGEN! in forum General Discussion
    Last Post: 12-31-2002, 04:42 AM
  5. sealing a box
    By brooksi in forum Subwoofers
    Last Post: 10-23-2002, 09:19 PM
