+ Reply to Thread
Page 2 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13 LastLast
Results 16 to 30 of 192
Reload Thread: SEALED vs PORTED (basic info.)
  1. #16
    BASS OUTLAW's Avatar
    BASS OUTLAW is offline Single sub fan
    Apr 2004
    next street
    27
    1,120
    Re: SEALED vs PORTED (basic info.)
    helotaxi thnx for info,
    so which one helps the woofer to handle more power :
    1- ported ?
    2- sealed ?
    a woofer that handles 300 rms in a sealed
    will not perform the same as the "same" woofer in a ported enclosure.
    when it comes to pushing it with 500 rms or so.
  2. #17
    helotaxi's Avatar
    helotaxi is offline Kilroy was Here
    Dec 2003
    South Central (New Mexico that is...)
    37
    8,945
    As far as power handling, the answer as always is "It depends". It depends on the sub. It depends on the enclosure, not just sealed or ported, but tuning and volume as well. Frequency at which the power is delivered is very important as well. Below tuning, excursion increases exponentially in a vented box. Right at tuning the sub can handle a huge amount of power mechanically (in regards to excursion anyway, the stresses involved may well rip the sub apart) but just above or anywhere below tuning excursion is much higher and power handling takes a pretty big hit. A smallish sealed box will have better power handling than a larger one but will need the extra power to compensate for a drop in efficiency. Really low frequencies can damage a sub in a sealed box as well, as it takes less power to reach excursion limits when subsonic frequencies are involved.
    If you really want a good idea of what the box does for power handling, get an enclosure program that does an excursion plot and play around with it a bit.
    Artificial Intelligence is no match for Natural Stupidity.
    Never underestimate the power of stupid people in large numbers.
    Life's tough...it's even tougher when you're stupid.
  3. #18
    Folly's Avatar
    Folly is offline Junior Member
    Aug 2004
    Los Angeles, CA
    14
    ok im making boxes for my 4 12" double stacked magnet subs......one dual box and 2 single.........which would be louder and sound better......ported or sealed they work with both......what do u all think?????
  4. #19
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    26
    15,596
    22
    ported will be louder
    as for SQ, its all subjective
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
  5. #20
    nweibley's Avatar
    nweibley is offline this:annoyinginsomanyways
    Jan 2004
    Tampa, FL
    26
    471
    I tend to think that a properly designed ported box will hit lower and have flatter response than that of a sealed. I don't really like sealed boxes much except in tight spaces and ultra ultra high SQ installs like adding extension to a BMW or Mercedes.... in those cases I like to find a great SQ driver and put it in a pretty decently sized sealed box for the sake of OEM look and a non "boomy" sound no matter what.
    If my Avatar doesn't make sense to you: Click Here
    hakuna matata
  6. #21
    chevy6998's Avatar
    chevy6998 is offline Senior VIP Member
    Jan 2005
    FAWN GROVE, PA
    193
    sweet thread, I learned alot!!!!!
  7. #22
    squeak9798's Avatar
    squeak9798 is offline Banned
    Jun 2004
    USA
    26,302
    Quote Originally Posted by chevy6998
    I'm more impressed with the fact that you actually used the search function to find it
  8. #23
    Nikuk's Avatar
    Nikuk is offline Been Gone Too Long
    Jul 2004
    Buffalo, NY
    32
    7,848
    Quote Originally Posted by squeak9798
    ...it's a sticky....
    Like your keyboard....
    What the f00k happened to this place?
  9. #24
    squeak9798's Avatar
    Jun 2004
    USA
    26,302
    Quote Originally Posted by NjccBflo
    LMAO...I'm a genius
  10. #25
    JimJ's Avatar
    JimJ is offline Tangled Up in Blue
    Jun 2004
    Hillsborough, NC
    31,691
    this is a sticky?
    with ten million web pages explaining this in detail?
  11. #26
    DBfan187's Avatar
    DBfan187 is offline Supa's mom was here!
    Jan 2003
    Poolside with Supa's mom.
    46,516
    1 Post(s)
    Quote Originally Posted by BASS OUTLAW
    Now we will start with :
    Sealed enclosures : A SEALED enclosure will be the smallest,and is the simplest of enclosures and will have good low frequency extension, but might not have the best low frequency extension. If space is limited.
    and its a good choice for SQ fans (Sound Quality).
    PORTED enclosures (Bass Reflex) : A PORTED enclosure will generally have a better low frequency extension for a given response shape,but would require a larger enclosure. If you made the enclosure as small as the sealed enclosure, but ported it to gain the low frequency response, the output would deviate from the desired flat response.
    Ported enclosures are slightly more difficult to design than a sealed enclosure. When using a sealed enclosure, it is difficult to be so far off as to risk damaging the woofers. In any type of enclosure, the woofer relies on the enclosure for damping. If there is insufficient damping, the woofer's cone will move significantly more than it should. The ported box will provide virtually no damping below the port frequency, all of the control will be provided by the woofer's suspension. Below the tuning (port) frequency, it is possible to cause damage to the woofer well before power levels approach the maximum power ratings of the woofer.
    common tunning frequencies :
    Sound Quality : 20 up to 28 Hz.
    Sound Quality Loudness : 30 up to 35 Hz
    Sound Pressure LeveL SPL : 40 up to 80 Hz (test tones are played rather than normal music, to avoid Low frequencies, which damages the speaker).
    Its commonly used for competition propose. and not everyday driving.(unless you like listening to test tones for everyday driving).
    BandPass enclosures (Single Reflex): Bandpass enclosure can sound good and give you a flat response,but most of the bandpass enclosures(in the market), are not designed for a flat response, this means that they are built to produce a large peak at some frequency from 50 to 60 Hz, these enclosures will work well with Rap, but generally they dont sound good with other types of music.
    if u use a banpass enclosure. it should be designed specificaly for your speaker.
    P.S : its not always recommended.
    hope that this info will help many to understand the different types of enclosures.and which type will perform better for their propose.
    -zAK
    :partytime
    Happy Birthday dude.
  12. #27
    Fareastkid's Avatar
    Fareastkid is offline Junior Member
    Mar 2005
    JAPAN
    15
    Icon9 Re: SEALED vs PORTED (basic info.)
    advice please,
    I'm thinking of picking up a pair of SPLW-15's, the factory says that the ported box should be tuned to 40Hz. but I want to use it for everyday banging and "maybe" some comp. Question, If I had a box built and tuned to 30 ~35Hz, would this damage the speakers? I live in japan and good subs cost a furtune here so please, some good sound advice..
    Sincerely,
    Fareastkid
  13. #28
    Fareastkid's Avatar
    Mar 2005
    JAPAN
    15
    advice please,
    Sincerely,
    Fareastkid
    ps.. here are the stats for the subs
    SPLW-15
    • 2800 watts power handling
    • 1400 watts RMS
    • 340 oz. magnet
    • 4” BASV/Kapton hybrid 18 awg voice coil
    • FS 29.1(Hz)
    • Vas 1.6 cu.ft.
    • Qes: 0.52 • Qms: 4.06 • Qts: 0.31
    • Xmax: 0.59”
    • SPL 92 dB
    • Sealed box: N/A
    • Ported box: 3.4 cu. ft.
    • Tuning: 40 Hz
    • Port size: 4” (dia) x 10” (length)
    • # of ports: 2
  14. #29
    Apr 2004
    next street
    27
    1,120
    its FS is 29.1hz ... u can tune it to 35 hz or so.. and even 30 hz ....
    the manufacturer rec. 40hz... because it gave the maximum sub potential to reproduce spl... when tested.... thats all i know.. wait for other replies...
  15. #30
    Fareastkid's Avatar
    Mar 2005
    JAPAN
    15
    Icon6 Re: SEALED vs PORTED (basic info.)
    zAK
    Thanks for your help, I thought I would never get any help.. but during all the waiting time, I decided to change and pick up a pair of S15L7's. The main reason for the change is that I could not find ANY FEEDBACK about the subs (splw-15), but.... when I entered kicker S15L7.. Man, I got more then enough!
    I just picked up my SPL Z1X3000D amp and I'm dam near dying to get everything connected, gonna run them @ 1ohm... any suggestions.. My car is 100% stock and the power wire is 8 gauge. I'm thinking of trying out in a SPL contest.. the box will be a street base box.. not enough space for a SPL/BASS box.. (kicker specs).. again..any advice?
    Fareastkid
+ Reply to Thread
  1. Sealed or Ported
    By actlsub in forum Subwoofers
    Last Post: 01-16-2003, 02:47 PM
  2. ported / sealed ??
    By limitkid7 in forum Subwoofers
    Last Post: 12-09-2002, 11:29 AM
  3. Need some opinions on ported or sealed.
    By 80_Cutlass_mn in forum Subwoofers
    Last Post: 11-20-2002, 01:00 AM
  4. Can ported have the same SQ as sealed?
    By kmu in forum Subwoofers
    Last Post: 10-03-2002, 01:30 PM
  5. Ported L7 12'' in F150 single cab vs 2 12'' sealed?
    By F150Matt in forum Wiring, Electrical and Installation Help
    Last Post: 07-07-2002, 06:34 PM
