+ Reply to Thread
Page 13 of 13 FirstFirst 1 2 3 4 5 6 7 8 9 10 11 12 13
Results 181 to 192 of 192
Reload Thread: SEALED vs PORTED (basic info.)
  1. #181
    Gilgamesh's Avatar
    Gilgamesh is offline Member
    Jan 2011
    Cottonport La.
    38
    58
    Re: SEALED vs PORTED (basic info.)
    I do have a question...I'm looking at a dual 12" vented enclosure tuned at 34Hz. it has one 6" vent port on one side and no divider and it is built very stout double baffle and all. Does it matter that there is no divider (seperate chambers)? Also can someone tell me does it matter if inside of the enclosure that the corners aren't rounded (curved)? i heard that the bass is smoother if the corners and the port is curved.....The enclosure is 5 cubic ft......Thanks for your help in advance!! OH YEAH....the specs. on my kicker comps are:sensitivity 89.1 db......frequency response 27-500 Hz. ...recommended rms power 150 watts....peak power 300 watts...Impedence 8 ohms......Someone please give me some good answers \m/
  2. #182
    huricaine's Avatar
    huricaine is offline 15 or 18 in a STD cab...
    May 2010
    port, ca
    206
    Quote Originally Posted by squeak9798 View Post
    I think you may have your terminology a little off there, or I am reading it wrong. The ported will have greater low frequency output down to the tuning, but a sealed with a decent Qtc will have greater low frequency extension (i.e. sealed can play lower than a ported box, but down around the tuning frequency the ported will have greater output).
    Also a good time to mention Hoffman's Iron Law:
    You can only have two of the following three at any one time;
    1) Small Box
    2) High Efficiency
    3) Low frequency extension
    If you want any two of them, then you must sacrifice the third.
    Sealead bloxes have less group delay, which means it has a more linear response on the rolloff. Like a 6db/octave highpass xover vs a 12db one for example, so it "sounds better".
    Anyway, you can sacrifice a little output at tunning for a lower extension, you can get the extension very low like 20hz, which is good.
    Depends on the sub, competition subs with an fs of about 46hz, and a low Qts will almost need to sacrifice efficiency for the extension.
    Ported boxes have MUUUUCH less distortion for high SPL applications on music vs sealed, for sure. Or atleast around tunning.
  3. #183
    SicAudio's Avatar
    SicAudio is offline did you fart dude?
    Apr 2009
    melting HO alts...
    42
    6,201
    Quote Originally Posted by Gilgamesh View Post
    that box is a bit too big for those subs FYI...3-3.2 is about the biggest i would go for them...
    but.... the shared chamber design is a plus.. it lets both subs compress the same air space and helps control the cone movement..which in turn increases the output..it also reduces the required airspace by about 10% - 25% per sub... IE. if each sub needs 1 cf each then the 2 same subs in 1 shared space would only need 1.5-1.8cf..
    almost all my boxes I do are shared space and i also do not round the interior corners unless the customer wants to pay the extra for it... the dif in sound at high volumes is negligable at best and I am positive no one can "hear" the difference...
    Quote Originally Posted by slammedincouch View Post
    Sic rolled me in front of my mom earlier...
    Quote Originally Posted by misfit138 View Post
    How did you manage to pack that much stupid into such a small amount of words?
    Quote Originally Posted by Magnus View Post
    I got rick rolled by SicAudio lulz
    I just got rick rolled by SicAudio again lulz.
    Quote Originally Posted by chickaboom View Post
    awww.... dude! I can't believe you were the first! to rick roll me! I am a noob!
    sold to: Johnny Law.Lulz/Worstenemy453,Pumkinman, j1b1e1, DexterMoped, miyagi gboo559,CSU87,nate2587, MichaelLane, SmLLySack. MR_Imperial, Herrrerra, ltr450racer690, 05fronty bought from: TripleB45, bigwheel15, (kroid77 but never recieved..)
    helping noobs daily PM me
  4. #184
    Heavylifter's Avatar
    Heavylifter is offline Member
    Dec 2010
    TN
    105
    After hearing my new ported setup, I will never do another sealed one
  5. Likes esmokah liked this post
  6. #185
    soldiermedic's Avatar
    soldiermedic is offline Noob4Life
    Nov 2008
    Puyallup, Wa
    253
    Quote Originally Posted by bigbang View Post
    A sealed box rolls off at about 12db/octave below f3, relatively shallow, whereas a ported box rolls off at about 18-24db/octave past f3, pretty sharp. The sealed box will give you alot of usable bass in the very low range, mid 20's and down, where in most automotive ported boxes, this low bass would be diminished or absent. A sealed box almost certainly gives you a smooth frequency response unless built too small, in which you will start gaining a midbass peak, so from a musical standpoint, they sound good because they are predictable, and you won't have a narrow band of a frequencies that are way too loud, or one-note-bass as in the case of a ported box tuned for output. The benefit of the ported box, besides output, is extra energy in the low frequencies, but I wouldent say they play lower. If you design a ported box for low frequency extension, not SPL, you can choose a sub and box to give the system an almost flat response, down to the port tuning frequency, where it drops sharply. In my opinion; a ported box tunned high for SPL. For the flattest response, a ported box tuned low with the correct sub. For the absolute lowest sub-bass frequencies or inaudible notes, the large sealed box. And as for group delay...
    Just browsing the thread getting ideas...ran across this thread. What if a sub is recommended for a sealed enclosure, but you graph a flat response by tuning ported and still get the low extension? I am working on a f3 of 27 which gives me a roll-off at 29, but I am not concerned about hitting any notes lower than 33hz noticeably.
  7. #186
    RAM_Designs's Avatar
    RAM_Designs is offline SketchUp Master
    Feb 2006
    Rockwall, TX
    27
    21,031
    97 Post(s)
    Quote Originally Posted by soldiermedic View Post
    What sub? With what you described you should be fine. F3 of 27hz is quite nice, and will play nearly anything you throw at it.
    1,000+ designs since March 2011...
    I have my PM's turned off, please email at Ryan@RAM-Designs.com
  8. #187
    Nov 2008
    Puyallup, Wa
    253
    Quote Originally Posted by RAM_Designs View Post
    It's an Infinity Perfect DVQ 12" with the mid insert, and it is recommended for a sealed box. But graphing it, I am seeing too much roll at too high of a frequency. However, when I played with it in WinISD and bass box pro, I got to a nice place on my graphing that gave me the f3 of 27, putting the tuning down to 18hz in a 2.5cf box. I know it seems a little extreme, but I get a flat response from 25hz on up, and I can get plenty power to the sub.
  9. #188
    code-man's Avatar
    code-man is offline Junior Member
    Sep 2011
    seattle
    i have a 1979 ford F-150 rag cab and im going to build a box for my p1222 jbl but i do not know if i should got ported or sealed i have 9 inches from floor to back of seat and it can be 16 inches tall and has 5 inches of room at the top from back cab wall to seat with about a 2 inches inbetween seat and the box but what kind of box should i build?
    thanks for the help
    oh and the box can be long ill get the exact mesurement if needed and i will power the sub for now off of a kenwood 800/800 thats until i can get me more power :P
  10. #189
    TDot's Avatar
    TDot is offline Member
    Oct 2012
    Bronx
    107
    These questions were asked that I am interested in, but were never answered.
    - Does the port location make much difference? I.E. front firing, top firing, rear firing or side firing
    - Does the port need to be a least one port diameter away from the box wall sides, rear wall and edge of sub? (does placement matter? How?)
    - Okay... how do you determine what a box is tuned at?
    - Also if a box is sealed does that mean it is not tuned?
    - If not with a sealed box does different size sealed boxes sound better than others? (How does the size of the sealed affect the sound, regardless of specs?)
  11. #190
    TDot's Avatar
    Oct 2012
    Bronx
    107
    bump
  12. #191
    TDot's Avatar
    Oct 2012
    Bronx
    107
    bump
  13. #192
    4bannger's Avatar
    4bannger is offline Member
    Nov 2012
    FLA
    89
    Was unsure if I could use a ported box in my truck know I know my answer. Helpful thread. Thanks
+ Reply to Thread
  1. Sealed or Ported
    By actlsub in forum Subwoofers
    Last Post: 01-16-2003, 02:47 PM
  2. ported / sealed ??
    By limitkid7 in forum Subwoofers
    Last Post: 12-09-2002, 11:29 AM
  3. Need some opinions on ported or sealed.
    By 80_Cutlass_mn in forum Subwoofers
    Last Post: 11-20-2002, 01:00 AM
  4. Can ported have the same SQ as sealed?
    By kmu in forum Subwoofers
    Last Post: 10-03-2002, 01:30 PM
  5. Ported L7 12'' in F150 single cab vs 2 12'' sealed?
    By F150Matt in forum Wiring, Electrical and Installation Help
    Last Post: 07-07-2002, 06:34 PM
