Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
Reload Thread: Question about ports
  1. #16
    monte_carlo97's Avatar
    monte_carlo97 is offline Power Acoustik Punk
    Feb 2004
    Central Ohio
    31
    3,509
    Re: Question about ports
    i don't get that end correction stuff
    97 Monte Carlo
    H/U - Kenwood Cd\MP3(KDC-MPV6022) - Up For Sale
    The All Power Acoustik System (Removed)
    Amps(2) - Class D 3000watt (A3000DB)
    Subs(2) - 15" MOFO 2600watt(MOFO-15)
    Caps(2) - 2.4 Farad Digital Cap (PC2.4)
    EQ(1) - 7 Band Preamp Graphic Equalizer (PEQ70)
    Rears(1 Pair) - 4-Way 6x9's (XP2K694)
    Fronts(1 Pair) - 2-Way 5 1/4's (XP2K52)
    Comp Set(1 Set) - 5 1/4 Component Set (XP2K50C)
    Comp Amp(1) - 4 Channel amp 960 watts max Plasma Sphere (TS960-4)
    Monitors(1) - 7" Widescreen TFT/LCD (PT713HRS)
    DVD H/U(1) - DVD Player (PADVD610)
    Box - 9 ft^3 box tuned to 35 hz.
    New System Yet To Be Determined. Although It Will Be All MA Audio.
  2. #17
    Zeph's Avatar
    Zeph is offline C eh, N eh, D eh
    Mar 2004
    Thunder Bay
    179
    If you mean like :
    then My guess is no..
    92 Plymouth Colt
    Alpine 9811 deck
    Alpine 5-1/4 speakers w/ silk dome tweeters
    Planet Audio P110 10" Sub in ported box
    PPI 240 2-way amp
  3. #18
    Acidburn's Avatar
    Acidburn is offline Super Mod-like-guy
    Dec 2003
    Tempe, AZ
    31
    15,596
    22
    no, you dont need the End Correction for that last pic as long as it is a couple inches from the back wall
    MdOiDcEtRaAtToOrR
    1996 Chevrolet Impala SS 14.5 @ 94
    1967 Chevrolet Camaro 18.4 @ 74
  4. #19
    sumone's Avatar
    sumone is offline CarAudio.com Veteran
    Dec 2003
    Midwest
    3,416
    off that jl site:
    An end correction factor is necesary because more often than not, one wall of the port is also one wall of the enclosure and this wall extends beyond the end of the port thus effectively adding length to the port
    ...To calculate end correction factor, simply add one-half of h [port_width] to the physical length you calculated above (L1 + L2) [vertical & horizontal components of the port length].
    so I guess basically an end-correction is needed whenever the last component of the port's wall also serves as the wall for the box.
    best sig of all time
  5. #20
    Acidburn's Avatar
    Dec 2003
    Tempe, AZ
    31
    15,596
    22
    yes... 10 char
    MdOiDcEtRaAtToOrR
  1. quick question on ports
    By pj_chevy03 in forum Enclosure Design & Construction Help
    Last Post: 07-15-2004, 03:32 AM
  2. Amp wiring question
    By Dookie in forum Amplifiers
    Last Post: 11-13-2003, 10:36 PM
  3. 1/4" MDF for ports?
    By SPLThunder in forum Enclosure Design & Construction Help
    Last Post: 09-19-2003, 10:13 AM
  4. Where do i put the ports if......
    By unard in forum Enclosure Design & Construction Help
    Last Post: 08-09-2003, 08:25 PM
