Results 1 to 7 of 7
Reload Thread: fiberglassing my box after i build it
    jtomsic's Avatar
    jtomsic is offline CarAudio.com Veteran
    Jan 2004
    Washington, Pennsylvania, United States
    32
    5,209
    19
    43 Post(s)
    im gonna be building a standard type of square subwoofer box, but i wanted to give it a glassed look, would fiberglass stay strong and not crack on these flat surfaces?
    Headunit: Pioneer AVH-P2300DVD
    Subwoofers: (2)15" RE Audio XXX(05 model)
    Sub Box: Undecided..
    Sub Amp: Crescendo bc3500
    Speakers: 6.5" RE Audio XXX Components(soon to be 2nd pair in kick panels)
    Speaker Amp: Hifonics HFi100.2(for now...)
    Wiring: 2 runs of 1/0 throughout, XS Power battery in trunk,big 3 done, 270a alt, 1/0 accesories throughout
    Deadner: 75sq ft AT 60mil, 20sq ft Alphadamp
    Security: Crimestopper 2way alarm/remote start
    ANeonRider's Avatar
    ANeonRider is offline teamSSAudio.com
    Aug 2004
    Saskatoon, SK, CAN
    36
    2,811
    Re: fiberglassing my box after i build it
    use bondo, not fibre if u want, but do u really need any of that? just make it smooth and prime, paint, etc
    Gauntlet's Avatar
    Gauntlet is offline bulletproof
    Oct 2002
    Cleveland, Ohio
    37
    8,477
    32
    What are you going to do?
    For the record, fiberglass is much stronger in curved shapes, and if you can use MDF for a flat surface, then do so.
    "The world is full of people who want nothing short of perfect,
    but settle for less, blinded by their quest for purpose."
    - Slug
    mrray13's Avatar
    mrray13 is offline uz some fegbags
    Dec 2001
    IL
    3,633
    are u going to build a trim ring(s) for the subs(s)?
    if so, then when u strecth the fleece, it'll have that nice arched look. plenty of resin and some cat hair should make it plenty strong. just remeber to wrap some around the edges of the box to tie it all together. i think it would work fine!
    what do u think ppl? will it work? i think so..that's how mine is done!
    ^^^ from this
    ^^^ to this
    ^^^ into this....the white marks are from scratching it putting it into the trunk..
    but basiclly i did exactly what you're talking about...i just did just like i typed...so far..so good!!
    wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee heheaheeahha
    Quote Originally Posted by lilmaniac2
    Your circles look like something a HMO doctor would do to a **** job ....
    ^^^ speaking about cbfryman's jigsaw ability
    owner of Thread posts 11111 & 12345
    wheeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee
    LimPerT's Avatar
    LimPerT is offline Senior VIP Member
    Apr 2004
    Grapevine, TX
    407
    ****... i like how that looks alot
    mrray13's Avatar
    Dec 2001
    IL
    3,633
    Quote Originally Posted by LimPerT
    thanks...it's in my wife's ride...2004 grand prix.
    now if only my truck had beats..hehe
    the sub is a soundsplinter rl-p..check em out here
    great sub..great ppl...holler at [email protected] <---he's totally cool!
    geolemon's Avatar
    geolemon is offline Senior VIP Member
    Mar 2003
    Buffalo, NY
    385
    That looks awesome, mrray. :cool2:
    If you are looking to simply smooth out the box, fill in screwholes and gaps, I've got a few installs on my personal page that essentially walk you through that process:
    www.betteraudio.com/geolemon
    Look in particular at the Projects Index, the Isobaric 6th Order Bandpass, and the Crazy Eights enclosure for some pics on the process.
    Also, I don't use Bondo for that (or for anything, for that matter).
    I use Plastic Wood brand (by DAP) filler, for it's good adhesion, low shrinkage, and easy sanding. It's meant for use with wood.
    If body filler is in order for some project (such as actual fiberglassing) - skip Bondo brand, it's generally regarded as the worst of the worst. Use another lightweight body filler, such as White Lightning, or even Dynatron... really just about anything else sands easier and shrinks less over time than Bondo.
  1. dual mdf box or form-fitted fiberglassed box in trunk?
    By sumone in forum Enclosure Design & Construction Help
    Last Post: 08-15-2004, 02:43 AM
  2. Fiberglassing inside of box???
    By bumpn_gt in forum Enclosure Design & Construction Help
    Last Post: 08-12-2004, 03:18 PM
  3. XXX and Box Situation
    By fury in forum Enclosure Design & Construction Help
    Last Post: 07-05-2004, 03:21 PM
  4. what do i need to make a box?
    By sylvr in forum Enclosure Design & Construction Help
    Last Post: 01-20-2004, 11:03 AM
