Results 1 to 8 of 8
Reload Thread: Correct box dimensions for RE HC?
    hooppro's Avatar
    hooppro is offline Member
    Jun 2004
    Seattle, WA
    47
    Just wanted to run these by everybody to make sure it the numbers are correct and if everything seems right
    2003 RE HC 15" in a 3.8ft^3 box tuned to ~32hz
    Internal dimensions - 31"(W) x 15"(H) x 20"(D)
    Port dimensions - 4"(W) x 15"(H) x 34.88" (L)
    The total internal volume is 5.38 minus the driver displacement = .19ft^3, minus the port volume = 1.211ft^3, minus the port bracing = .18ft^3 which all = 3.8ft^3...
    This sounds right? Do I need any additional bracing?
    Thanks
    hooppro's Avatar
    Jun 2004
    Seattle, WA
    47
    Re: Correct box dimensions for RE HC?
    I looked at the numbers again and I am not sure what you mean...which displacement is wrong?
    thanks for your time
    packerfan's Avatar
    packerfan is offline CarAudio.com Veteran
    Jan 2003
    Beaver Dam WI
    26
    3,809
    Quote Originally Posted by Jmac
    1) I know they're wrong because you just multiplied the port dimensions (4*15*34.88/1728 = 1.211 ft^3)
    2) I can get 0.19 ft^3 using 5/8" MDF, but you really shouldn't be using 5/8" MDF ... I'd say 3/4" MDF is bare minimum for a driver of this magnitude in an enclosure of this size. Also, since driver displacement for an HC15 is 0.18 ft^3, I think you mixed the numbers up in your first post.
    3) You never specified the thickness of the walls (specifically the baffle the port passes through). This is quite important as this portion of the port that passes through the wall does not take up space within the enclosure ...
    4) How your port is laid out can affect your tuning frequency and must be accounted for ... I'd say your enclosure is tuned 1-2 Hz below 32 Hz ...
    You need a box building tutorial now
    Eclipse CD7000
    MTX TA7804
    Eclipse SC8365
    MTX TA92001
    9 Elemental Designs 13Ov.2's (15.5 cu ft ported box)
    O/1g All around, 2 Yellow tops, big 3.
    hooppro's Avatar
    Jun 2004
    Seattle, WA
    47
    wow feel like an idiot now...can anyone help with how i should go about correcting these problems...???
    I am planning on using 3/4" mdf throughout the entire enclosure and the port will be running along the far right side of the box and than along the back wall...
    Does 1.14t^3 sound correct for the port volume?
    hooppro's Avatar
    Jun 2004
    Seattle, WA
    47
    anyone?!?!?!
    hooppro's Avatar
    Jun 2004
    Seattle, WA
    47
    heres a link to what my box is going to look like...i think...double check my calculations?
    thanks
    hooppro's Avatar
    Jun 2004
    Seattle, WA
    47
    hooppro's Avatar
    Jun 2004
    Seattle, WA
    47
    thank you for the help
  1. box is finshed (pics)
    By bass maniak in forum General Discussion
    Last Post: 11-30-2005, 09:17 AM
  2. Best 15" Box Dimensions
    By Electro16 in forum Enclosure Design & Construction Help
    Last Post: 05-05-2004, 11:01 PM
  3. Sound Quality: The Sealed/Ported misconception
    Last Post: 02-28-2004, 05:15 PM
  4. custom box dimensions
    By whitebread07 in forum Enclosure Design & Construction Help
    Last Post: 12-09-2003, 10:35 PM
  5. help me with a box for JBL GTI 10s
    By slug420 in forum Enclosure Design & Construction Help
    Last Post: 10-28-2003, 10:51 AM
