+ Reply to Thread
Results 1 to 11 of 11
Reload Thread: Opps measure twice
    ronin1717's Avatar
    ronin1717 is online now Member
    Apr 2017
    tx
    130
    2 Post(s)
    48 Post(s)
    Opps measure twice
    Ok so opps made a mistake...yaddi yaddi yaddi
    Had my cuts made for an subs up port back areo port enclosure.
    Opps right measurements wrong cuts or however you'd say it. My top/bottom cuts are my front / back of that makes any sense.
    Any suggestions other than re-cut , since that's a known option.
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,520
    14 Post(s)
    2182 Post(s)
    Re: Opps measure twice
    Buy more wood and recut the top and bottom or cut the side panels shorter for less depth. Did you give the correct dimensions to whoever cut the wood? If so and if its a store then I would back there and make them give you the correct sizes.
    Boomin_tahoe's Avatar
    Boomin_tahoe is online now Hurtin' feelings errrday.
    Jul 2005
    WA
    14,265
    41 Post(s)
    6039 Post(s)
    It's "oops"
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    Polk Audio MM6501 comps
    ronin1717's Avatar
    Apr 2017
    tx
    130
    2 Post(s)
    48 Post(s)
    It's "oops"
    Opps! it is oops opps did it again lol
    Anywho... Thanks @THATpurpleKUSH I just did re cuts
    ronin1717's Avatar
    Apr 2017
    tx
    130
    2 Post(s)
    48 Post(s)
    Any glue preferences
    Jul 2005
    WA
    14,265
    41 Post(s)
    6039 Post(s)
    Tightbond
    Only logical fix would be recut those pieces again. Don't want any gaps of any size.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
    ronin1717's Avatar
    Apr 2017
    tx
    130
    2 Post(s)
    48 Post(s)
    Tightbond
    It's "oops"
    Yep you're right re cuts done
    Thanks for the titebond recommendation.
    that's what I had planned just checking other options
    Sep 2009
    5,520
    14 Post(s)
    2182 Post(s)
    Quote Originally Posted by ronin1717 View Post
    YW, just beware that your net volume is now smaller which will shift the port tune slightly higher. I use Titebond to glue the panels together then I use DAP Alex Plus Fast Dry to seal the inner seams. That way I know the seams have no leaks.
  9. #9
    ronin1717's Avatar
    Apr 2017
    tx
    130
    2 Post(s)
    48 Post(s)
    It all worked out , they laughed at my mistake so I got enough extra board to re-cut the 2 short pieces...all original dimensions now.
    Thanks
  10. #10
    Jul 2005
    WA
    14,265
    41 Post(s)
    6039 Post(s)
    I would like to request pics.
    97 4 dr. Tahoe
    Interstate battery
    Alpine 9835
  11. #11
    Louisiana_CRX's Avatar
    Louisiana_CRX is online now dem shoes......
    Aug 2006
    Piney Hills of Louisiana
    37,550
    24 Post(s)
    1886 Post(s)
    You can make the box slightly smaller..it shouldn’t make much difference
    Current 2010 Louisiana USACi State Records :
    Trunk 0-1000.................. 151.3
    StreetBeat 2................... 145.6
    Stock 1801-up.................153.8
    SuperStock 1801-up..........154.2
    Top three in 11 out of 26 power classes and Louisiana USACi Points Leader at 465
+ Reply to Thread
