+ Reply to Thread
Results 1 to 6 of 6
Reload Thread: Enclosure for JL 12W6V2
    Bdozers's Avatar
    Bdozers is online now Junior Member
    Apr 2017
    San Jose, CA
    14
    11 Post(s)
    Hi guys,
    I'm gonna go pick up a used JL 12W6V2 tomorrow. Would this enclosure be okay for the unit? https://www.frys.com/product/6192219
    Also - I'm borrowing my friend's 1200watt amp to test the unit (I'm currently running a powered sub off 8 gauge wire). Will this be okay as long as I don't bump up the volume? Any things I should look out for when I look at the unit? Thanks in advance!
    THATpurpleKUSH's Avatar
    THATpurpleKUSH is online now Smoke weed everyday
    Sep 2009
    Banging gears and passing queeers
    5,520
    14 Post(s)
    2182 Post(s)
    Re: Enclosure for JL 12W6V2
    You can use a multimeter to check the coils instead of hooking it up to an amp, that box will be fine.
    Bdozers's Avatar
    Apr 2017
    San Jose, CA
    14
    11 Post(s)
    Didn't think about using a multimeter. Thanks for the tip!
    Buck's Avatar
    Buck is online now always low Buck is a Supporting Member of the forum!
    May 2008
    Nashville
    18,673
    29 Post(s)
    1130 Post(s)
    i can design you a ported for the jl
    they do really well ported, very clean and tight woofers. still get loud too, just don't overpower it too much
    Alpine - ASE (local) - Batcap - CT Sounds - eD - Excessive Amperage - Powerware - Rainbow
    Buck's Avatar
    May 2008
    Nashville
    18,673
    29 Post(s)
    1130 Post(s)
    that sealed box is sad for a jl woofer that costs so much lol
    pw91686's Avatar
    pw91686 is offline CarAudio.com Elite
    Jan 2005
    Mobile, AL
    1,153
    2 Post(s)
    76 Post(s)
    that sealed enclosure will not work well with the jl 12w6. it is only .75 cubic feet, so after subwoofer displacement you are looking at around .65 cubic feet. jl recommends 1.25 cubic feet for a sealed enclosure.
    if you just want a cheap enclosure for now get one of these:
    https://belvaproducts.com/mdfs1215-1...fer-enclosure/
    https://www.ebay.com/itm/Q-POWER-QBO...cAAOSwLmda2khq
    and line it with some acoustic dampening material.
    2004 Honda S2000
    Pioneer DEH-80-PRS
    new build in progress (most likely audison voce av k6, tc sounds tc-1000 8, phoenix gold ti21600.5
+ Reply to Thread
