+ Reply to Thread
Results 1 to 11 of 11
Reload Thread: 2X12" OR 1X15" which sounds deeper?
    XxAndreaxX's Avatar
    XxAndreaxX is offline Member
    Mar 2016
    spain
    133
    79 Post(s)
    I know given the same Output WATTS, 2x12" will sound louder than 1x15".
    but I don't want louder sound, but I'm searching for deeper bass.
    I know 1 single 15 will sound deeper than single 12 because of the physics of the bigger membrane.
    given the extra Surface área of the 2x12", will it be posible to get more low end bass out of it than a single 15??
    thanks
    garychoffmann's Avatar
    garychoffmann is online now CarAudio.com Elite
    Mar 2011
    Missouri
    1,987
    6 Post(s)
    548 Post(s)
    Re: 2X12" OR 1X15" which sounds deeper?
    A 12 or 15 will play the same range. One can go just as deep as the other and response is enclosure dependent. 2 12's would be louder based upon cone area of the exact same woofers. Assuming a correct box and same amplifier are used.
    Jeffdachef's Avatar
    Jeffdachef is offline Gunz That Turn on Nunz
    Feb 2013
    South Coast Metro, CA
    16,187
    245 Post(s)
    7915 Post(s)
    Quote Originally Posted by XxAndreaxX View Post
    thanks
    Completely wrong, whoever told you that is a complete idiot.
    09 Sienna Subs : Four Team Ascendant 18s......Sub amp: Two Taramps 15k
    Headunit: Pioneer 80PRS................................Mids/Highs amp: CT 500.2, ppi 600.2, ppi 900.4 bridged
    Front stage: Two PWX 10s per door midbass only....... PRV 6MR500 midrange....... Massive CT 2 german tweeters.
    320 amp Singer alt....... 1 group 34 under the hood 6 group31 agms in the back 560 amp hours total.
    ronin1717's Avatar
    ronin1717 is online now Member
    Apr 2017
    tx
    135
    2 Post(s)
    52 Post(s)
    Your box is what's crucial,... nevermind the bigger membrane nonsense. You want crush some lows fine an experienced box builder, discuss your goals and equipment sub , amp , electrical, vehicle...and you should be good to go
    XxAndreaxX's Avatar
    Mar 2016
    spain
    133
    79 Post(s)
    my goal is the deepest bass posible, cheapest way and spacesaving. My car is a sedane, alfa romeo 159.
    I could fit 2x 15" using the whole trunk, putting the port-tube on the back of the sub, that separates the trunk from the cockpit.
    could the trunk act as enclosure itself???
    kr15's Avatar
    kr15 is offline Polluting Residentials
    Feb 2010
    California
    6,669
    29 Post(s)
    1488 Post(s)
    Less is more
    Team Flex Issues
    JVF Customz
    REFS- Supergumby5000, Lastcall, 919motoring, hippishake, daboyfromdabx (great seller), beach22
    Jeffdachef's Avatar
    Feb 2013
    16,187
    245 Post(s)
    7915 Post(s)
    whats your definition of deep bass? Actual deep bass(10-25hz) doesnt really feel all that loud(unless you are 155+ db at those freqs), its mainly a wind tunnel with a lot of pressure. Other people who never experience deep bass think 32hz is deep which is really not deep at all.
    Getting deep bass mainly is from how the enclosure is designed and how it interacts with your vehicle's peak frequency. Its a lot harder to get lows out of a smaller car with a high resonant frequency which will require a lot of deadening to lower the peak along with a low tuned box or 4th order or even a wall.
    XxAndreaxX's Avatar
    Mar 2016
    spain
    133
    79 Post(s)
    Ok, I'll search 2x 15" subs, not more expensive than 120€ each, with good excursión (Xmax min 20mm) but Little wattage, my amp makes max 1600W RMS at 1ohm
    You know some Brand that fits these specs?
  9. #9
    XxAndreaxX's Avatar
    Mar 2016
    spain
    133
    79 Post(s)
    I've also found a Skar Audio EVL 18" for a good Price, but then shipping is too expensive here in spain.
  10. #10
    Hertz Mafia's Avatar
    Hertz Mafia is online now FEATHER RUFFLER
    Jul 2016
    Michigan
    2,176
    44 Post(s)
    1397 Post(s)
    Got ground zero over there? They make some decent stuff. Or what about pride audio? Got those in Spain?
  11. #11
    XxAndreaxX's Avatar
    Mar 2016
    spain
    133
    79 Post(s)
    Quote Originally Posted by Hertz Mafia View Post
    I've not seen 18" at Pride, and ground zero is waaaay to expensive for me.
    I saw the 18" of Skar audio at 240$ low wattage and high excursión. that would be perfect for my needs.
+ Reply to Thread
